Hi all,
I was trying to install musicbrainz database (following this guide, hat tip zufallshed) inside a virtualbox jail.
Everything went fine until I tried to use the virtual machine (as recommended by guide above, following musicbrainz instructions).
As the console is run by a vnc wiever app for java, it was blocked by recent enhanced security criteria by java.
I tried adding the jail musicbrainz ip (192.168.1.9 in my case, as well as 192.168.1.9:3389) to the java console exception list to no avail.
Error: access denied ("java.net.SocketPermission" "192.168.1.9:3389" "connect,resolve")
java.security.AccessControlException: access denied ("java.net.SocketPermission" "192.168.1.9:3389" "connect,resolve")
at java.security.AccessControlContext.checkPermission(Unknown Source)
at java.security.AccessController.checkPermission(Unknown Source)
at java.lang.SecurityManager.checkPermission(Unknown Source)
at java.lang.SecurityManager.checkConnect(Unknown Source)
at sun.plugin2.applet.SecurityManagerHelper.checkConnectHelper(Unknown Source)
at sun.plugin2.applet.AWTAppletSecurityManager.checkConnect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at java.net.Socket.<init>(Unknown Source)
at RfbProto.<init>(RfbProto.java:229)
at VncViewer.connectAndAuthenticate(VncViewer.java:325)
at VncViewer.run(VncViewer.java:158)
at java.lang.Thread.run(Unknown Source)
Any idea how to get around this ?
Thanks
Thanks
