itvend
- Sep 8, 2017
I have question what do i have to do to get better performance? I am running FreeNAS 11 in VM and i am not getting very good speeds with virtio. Download 60Mbytes and upload 40Mbytes. i tested my virtual network. Every other vm achieves 100Mbytes/s speed and even my pFSense in VM work fine. i just dont know what magical variables i have to set or unset to get it working.
what i have tried:
/boot/loader.conf (( i hope there no need to recompile something ))
i am measuring speeds with iperf3
EDIT:
vtnet works fine in pure FreeBSD 11.1 env speed max out nicely, and i noticed that my options don't go trough ifconfig vtnet0 rxsum if i do ifconfig vtnet options line stays same.
Thanks fur help :)
what i have tried:
ifconfig vtnet0 -lro -tso -rxcsum -txcsum
hw.vtnet.csum_disable=1 hw.vtnet.tso_disable=1 hw.vtnet.lro_disable=1
root@freenas:~ # uname -a FreeBSD freenas.itvend.eu 11.0-STABLE FreeBSD 11.0-STABLE #0 r321665+c0805687fec(freenas/11.0-stable): Tue Sep 5 16:07:24 UTC 2017 root@gauntlet:/freenas-11-releng/freenas/_BE/objs/freenas-11-releng/freenas/_BE/os/sys/FreeNAS.amd64 amd64
EDIT:
root@freenas:~ # ifconfig vtnet0 vtnet0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=80028<VLAN_MTU,JUMBO_MTU,LINKSTATE> ether 52:54:00:87:4d:fe inet 192.168.0.5 netmask 0xffffff00 broadcast 192.168.0.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet 10Gbase-T <full-duplex> status: active
Thanks fur help :)
