Version of Network UPS Tools?
Patrick M. Hausen
Hi all,
could someone already running the BETA please check which version of NUT is on board?
upscmd -h
should do the trick.
PhilD13
In Dragonfish-24.04-RC.1 the command returns
Network UPS Tools upscmd 2.8.0
which is the same returned in the current Cobia TrueNAS-SCALE-23.10.2
Patrick M. Hausen
That's the broken version. We need 2.8.1. I'll open a ticket.
Thanks!
PhilD13
That's probably why It wouldn't work at first on my recently updated Cobia system.
PhilD13
What issue did you find?
I actually don't think it was the Cobia system that had an issue though the service was turned off and not set for autostart, but I can't say that at this point not actually an error on my part during setup. On DragonfishRC which is running on VirtualBox as a VM it is also now working and providing charts. I just needed to configure the service first then enable it.
Patrick M. Hausen
2.8.0 does not read the UPS state from Cyberpower SNMP cards. 2.8.1 allegedly does.
