Ok, I understand your point, bot I do not agree completely with you, especially because I did my homework before doing this. BUT, this is going out of topic, and we should not want to continue further.
Going back to the main question, I did some research and I found out a way to do it.
Maybe it is not the right one, and surely it is not supported, but for the ones who want to try it I can follow these steps:
Prerequisites:
Ensure you have SSH access as
root to your TrueNAS; also, locate (or create) the VM you want to attach the disks and
power it on (the attach is not possible if the VM is not running). It is a good thing to have the Guest OS already set up and running.
Note that this procedure uses the utility
virsh, available by default on TrueNAS Scale 22.02-RC2.
Procedure:
1. Login to TrueNAS using SSH with
root user
2. Locate the disk(s) you want to pass to the VM. The right thing is to not use the standard name (like
/dev/sda etc...), but use the ID provided by
/dev/disk/by-id. To locate them, this command can be really useful:
find /dev/disk/by-id/ -type l|xargs -I{} ls -l {}|grep -v -E '[0-9]$' |sort -k11|cut -d' ' -f9,10,11,12
Here an example outout:
root@datacenter[~]# find /dev/disk/by-id/ -type l|xargs -I{} ls -l {}|grep -v -E '[0-9]$' |sort -k11|cut -d' ' -f9,10,11,12 | sort
/dev/disk/by-id/ata-KINGSTON_SA400M8120G_50026B7685357785 -> ../../sdn
/dev/disk/by-id/ata-ST16000NM001G-2KK103_ZL2KB41G -> ../../sdb
/dev/disk/by-id/ata-ST16000NM001G-2KK103_ZL2KG36H -> ../../sdd
/dev/disk/by-id/ata-ST16000NM001G-2KK103_ZL2KG8BD -> ../../sda
/dev/disk/by-id/ata-ST16000NM001G-2KK103_ZL2KGSRT -> ../../sdc
/dev/disk/by-id/ata-Samsung_SSD_850_EVO_500GB_S21JNSAG158509B -> ../../sdj
/dev/disk/by-id/ata-Samsung_SSD_850_EVO_500GB_S2RBNX0H937583L -> ../../sdk
/dev/disk/by-id/ata-WDC_WD10JFCX-68N6GN0_WD-WX11A15ET12E -> ../../sdm
/dev/disk/by-id/ata-WDC_WD10JFCX-68N6GN0_WD-WX11A15ETRZ9 -> ../../sdl
/dev/disk/by-id/ata-WDC_WD40EFRX-68N32N0_WD-WCC7K1DFDE54 -> ../../sdi
/dev/disk/by-id/ata-WDC_WD40EFRX-68WT0N0_WD-WCC4E0135118 -> ../../sde
/dev/disk/by-id/ata-WDC_WD40EFRX-68WT0N0_WD-WCC4E0185240 -> ../../sdh
/dev/disk/by-id/ata-WDC_WD40EFRX-68WT0N0_WD-WCC4E0243702 -> ../../sdg
/dev/disk/by-id/ata-WDC_WD40EFRX-68WT0N0_WD-WCC4ENSDRE27 -> ../../sdf
/dev/disk/by-id/wwn-0x5000c500dbd815d2 -> ../../sdb
/dev/disk/by-id/wwn-0x5000c500dbe1b5b7 -> ../../sdd
/dev/disk/by-id/wwn-0x5000c500dbe40981 -> ../../sdc
/dev/disk/by-id/wwn-0x5000c500dbe46e89 -> ../../sda
/dev/disk/by-id/wwn-0x50014ee209112b98 -> ../../sde
/dev/disk/by-id/wwn-0x50014ee20b01a0fc -> ../../sdf
/dev/disk/by-id/wwn-0x50014ee210a8b4bc -> ../../sdi
/dev/disk/by-id/wwn-0x50014ee25e74959c -> ../../sdg
/dev/disk/by-id/wwn-0x50014ee2b3bbed86 -> ../../sdh
/dev/disk/by-id/wwn-0x50014ee6b01bee55 -> ../../sdl
/dev/disk/by-id/wwn-0x50014ee6b01bfbaa -> ../../sdm
/dev/disk/by-id/wwn-0x5002538d414b3774 -> ../../sdk
/dev/disk/by-id/wwn-0x5002538da015f254 -> ../../sdj
/dev/disk/by-id/wwn-0x50026b7685357785 -> ../../sdn
root@datacenter[~]#
In this output, it is possible to see each available disk with its ID and its name, therefore identify them is easy.
3. For each disk you want to passthrough, decide for a
Target Name. This is only a name used by QEMU to refer to the disk. The name must be in Linux standard, therefore an easy way is to replace the first letter of the existing name with
v.
E.g.:
sdj becomes
vdj
4. Make
virsh to connect to the QEMU environment. Connection is made through a socket, which on TrueNAS Scale seems to be located at
/run/truenas_libvirt/libvirt-sock=. The most obvious way is to create an alias:
alias virsh='virsh -c "qemu+unix:///system?socket=/run/truenas_libvirt/libvirt-sock" $1'
4. Find the name of your VM. This is required because the VM Name is slightly different from the one showed by TrueNAS Web Gui:
virsh list --all
Here an example output (note that on TrueNAS this VM is called
mover).
root@datacenter[~]# virsh list --all
 Id   Name      State
 7    1_mover   running
root@datacenter[~]#
5. Attach the disk(s) using the info gathered until now:
virsh attach-disk <VM Name> <Disk ID> <Target Name>
Here an example:
virsh attach-disk 1_mover /dev/disk/by-id/ata-Samsung_SSD_850_EVO_500GB_S21JNSAG158509B vdj
Remember the attach is not persistent: if you perform a reboot inside the Guest OS, everything is fine, but if you Power Off or Restart the VM from TrueNAS, the attached disks will disappear. Anyway, reattaching can be done following this procedure again.
One last notice: disks will be passed through using virtIo emulation. Going away from the technical details, it only means you MIGHT require additional drivers on your Guest OS to correctly identify and use the attached device. For Windows, you can find virtIo drivers here:
https://github.com/virtio-win/virtio-win-pkg-scripts/blob/master/README.md
Hope this will help in the future.
