Passing through single GPU to VM
stavros-k
Hey, according to this i need 2 GPU in order to pass one to VM.
TN is running i headless mode anyway. Why i can't use the GPU?
In unraid(slackware) at boot i run
echo 0 > /sys/class/vtconsole/vtcon0/bind
echo 0 > /sys/class/vtconsole/vtcon1/bind
echo efi-framebuffer.0 > /sys/bus/platform/drivers/efi-framebuffer/unbind
And GPU can be used on a VM. (OFC i don't use the console menu in the display even after VM is shutdown).
Is this a limitation with debian or the hypervisor? Or this could be implemented (If so, i can open a jira ticket)?
ornias
It varies a lot with hardware, OS and hypervisor (versions) if you are able to do what you propose.
Thats also why iX is not likely to ever implement this.
But you can always file a Jira suggestion ofcoarse! :)
Snow
I see a date of 2020 on this issues, has this been completed?
