USB stick / CAM status: CCB request completed with an error
BlazeStar
Not sure which category to use for this but here goes:
Using FreeNAS-9.10-STABLE-201605021851
I received a "daily security run output" email saying this:
(da4:umass-sim0:0:0:0): READ(10). CDB: 28 00 00 a1 1f 55 00 00 16 00
(da4:umass-sim0:0:0:0): CAM status: CCB request completed with an error
(da4:umass-sim0:0:0:0): Retrying command
(da4:umass-sim0:0:0:0): READ(10). CDB: 28 00 00 c0 61 81 00 00 d4 00
(da5:umass-sim1:1:0:0): READ(10). CDB: 28 00 00 c0 61 81 00 00 d4 00
(da5:umass-sim1:1:0:0): CAM status: CCB request completed with an error
(da5:umass-sim1:1:0:0): Retrying command
No sure what's going on here?
I think it's referring to the USB stick running FreeNAS so I'm a little worried.
It refers to two SCSI devices.
USB mass storage is presented to the OS as SCSI, so it could very well be the boot device(s). However, it's hard to say anything specific with so little data.
camcontrol devlist would be useful, as would a description of the system's storage layout (including boot devices)...
BlazeStar
The system layout is as follow:
Boot is two mirrored USB sticks: http://grab.by/Qmja
Storage is two pools :
  • First pools is 4 X 4TB drives in stripped mirrors, with 1 SSD drive for logs and 1 SSD drive for cache : http://grab.by/Qmjk
  • Second pool is just one drive that's there to be used as a local RSYNC backup and could also be used as spare : http://grab.by/Qmjy
The output of cam control devlist is as follow:
[root@NAS ~]# camcontrol devlist
<ATA WDC WD4003FZEX-0 1A01>        at scbus0 target 0 lun 0 (da0,pass0)
<ATA WDC WD4003FZEX-0 1A01>        at scbus0 target 1 lun 0 (da1,pass1)
<ATA WDC WD4003FZEX-0 1A01>        at scbus0 target 2 lun 0 (da2,pass2)
<ATA WDC WD4003FZEX-0 1A01>        at scbus0 target 3 lun 0 (da3,pass3)
<INTEL SSDSC2BB080G4 D2010370>     at scbus1 target 0 lun 0 (ada0,pass4)
<INTEL SSDSC2BB080G4 D2010370>     at scbus2 target 0 lun 0 (ada1,pass5)
<WDC WD40EFRX-68WT0N0 80.00A80>    at scbus6 target 0 lun 0 (ada2,pass6)
<Kingston DataTraveler 3.0 PMAP>   at scbus8 target 0 lun 0 (da4,pass7)
<Kingston DataTraveler 3.0 PMAP>   at scbus9 target 0 lun 0 (da5,pass8)
Ok, so your boot devices may be crapping out or it might've been a weird USB controller issue.
Well, I'd run a scrub, see if there are any errors and just generally keep an eye on them.
BlazeStar
Well I manually started a scrub yesterday.
I'm not sure how to read the results?
I did not get any email concerning that.
I was trying to read the documentation : https://doc.freenas.org/9.3/freenas_system.html#boot
But I can't find where I can see the results of the scrub...
The only thing I can see in the GUI is this:
Boot Volume Condition: HEALTHY
Last Scrub Run on: Wed May 25 00:22:35 2016
So I'm not sure if there's something I should be doing at this point?
That's the result of the scrub. If problems were found, that's where it would tell you (and, if email notifications are set up properly, it will notify you as well).
Iz Oz
I had the exact same problem with essentially the same setup. I have the same posted message
on one of my mirrored USB boot drives. Ran a scrub and and the condition came back as Healthy.
Curious to know what came out of your setup, did you end up replacing the USB drives?
BlazeStar
I had the exact same problem with essentially the same setup. I have the same posted message on one of my mirrored USB boot drives. Ran a scrub and and the condition came back as Healthy.
Nope... I have two mirrored USB drives... I couldn't find the one that was faulty, if there is one that is faulty.
So I just let that be for now....
