kingdorian
- Feb 3, 2013
Hi Guys,
I've got a problem with installing/booting FreeNAS from an USB, I've put the img on the usb using win2diskimage, all went fine until I tried to boot my NAS from the usb. I think I've set the bios settings properly to boot from the usb. But when I run I get the error message: "Reboot and Select prober Boot device or Insert Boot Media in selected Boot device and press a key". I've googeling this error message for over an hour now with no result. However when I try to boot my main pc (the one I'm using right now) from this usb all works fine it boots from the usb.
So I hope you guys can help me out because it is propably an noob question and an easy fix....
My system specs:
mobo: ASRock E350M1
hdd: Seagate barracuda 2TB
ram: corsair valueselect 2x4GB ddr3 1333mhz
If you guys need to know more just ask and I'll try to awnser it
THANKS A LOT!
p.s. I'm Dutch and dyslectic so sorry for my verry bad English ;(
My system specs:
mobo: ASRock E350M1
THANKS A LOT!
