rvassar
- May 2, 2018
In case anyone is wondering... This pool was created just before the system was left up.
Since I'm out of SATA ports on my motherboard, and don't have a proper HBA available at the moment, I am going to try the USB->SATA enclosure experiment, with a couple 60Gb Patriot SSD's.
https://www.newegg.com/Product/Prod...m_re=Patriot_Flare-_-0D9-003W-00031-_-Product
Those should at least get me wear levelling. I suspect I'll be working on Build 2.0 by fall.
pool: freenas-boot state: DEGRADED status: One or more devices are faulted in response to persistent errors. Sufficient replicas exist for the pool to continue functioning in a degraded state. action: Replace the faulted device, or use 'zpool clear' to mark the device repaired. scan: scrub repaired 0 in 0 days 00:00:44 with 0 errors on Sat Jun 2 03:45:44 2018 config: NAME STATE READ WRITE CKSUM freenas-boot DEGRADED 0 0 0 mirror-0 DEGRADED 0 0 0 da0p2 ONLINE 0 0 0 da1p2 FAULTED 0 227 0 too many errors # uptime 8:20PM up 28 days, 4:16, 1 user, load averages: 0.29, 0.27, 0.25
