Hello Forum,
I am using a Freenas 8.0.3-32Bit where a Cyberpower GP600 UPS is connected via USB cable.
The usb is using the usb-hid driver and the UPS Service is turned on. This setup is working well and the server will shut down as expected.
But after a reboot the service won't restart automatically, so the server doesn't recognize the UPS any more, even tough the UPS service is turn on in the service tab. I need to turn off and on this service to enable proper function again.
See the log below:
Jan 16 20:48:34 freenas kernel: ugen0.2: <CPS> at usbus0
Jan 16 20:48:34 freenas root: Unknown USB device: vendor 0x0764 product 0x0501 bus uhub0
Jan 16 20:48:38 freenas upsmon[1625]: UPS [ups]: connect failed: Connection failure: Connection refused
Jan 16 20:48:41 freenas kernel: ugen0.2: <CPS> at usbus0 (disconnected)
(repeated every few seconds)
(turning this service off and on again)
Jan 16 20:48:52 freenas freenas[1765]: Executing: /usr/sbin/service ix-ups quietstart
Jan 16 20:48:53 freenas kernel: ugen0.2: <CPS> at usbus0 (disconnected)
Jan 16 20:48:53 freenas upsmon[1625]: UPS [ups]: connect failed: Connection failure: Connection refused
Jan 16 20:48:53 freenas freenas[1765]: Executing: /usr/sbin/service nut restart
Jan 16 20:48:53 freenas freenas: Will not 'restart' nut because nut_enable is NO.
Jan 16 20:48:53 freenas freenas[1765]: Executing: /usr/sbin/service nut_upsmon restart
Jan 16 20:48:53 freenas freenas: Stopping nut_upsmon.
Jan 16 20:48:53 freenas upsmon[1623]: upsmon parent: read
Jan 16 20:48:53 freenas freenas: Will not 'start' nut_upsmon because nut_upsmon_enable is NO.
Jan 16 20:48:53 freenas freenas[1765]: Executing: /usr/sbin/service nut_upslog restart
Jan 16 20:48:53 freenas freenas: Stopping nut_upslog.
Jan 16 20:48:53 freenas freenas: Will not 'start' nut_upslog because nut_upslog_enable is NO.
Jan 16 20:48:54 freenas freenas[1765]: Executing: /bin/pgrep -F /var/db/nut/upsd.pid upsd
Jan 16 20:48:55 freenas freenas[1765]: Executing: /usr/sbin/service ix-ups quietstart
Jan 16 20:48:56 freenas root: Unknown USB device: vendor 0x0764 product 0x0501 bus uhub0
Jan 16 20:48:56 freenas kernel: ugen0.2: <CPS> at usbus0
Jan 16 20:48:56 freenas freenas[1765]: Executing: /usr/sbin/service nut restart
Jan 16 20:48:56 freenas freenas: nut not running? (check /var/db/nut/upsd.pid).
Jan 16 20:48:57 freenas freenas: Using subdriver: CyberPower HID 0.3
Jan 16 20:48:57 freenas freenas: Network UPS Tools - Generic HID driver 0.35 (2.6.2)
Jan 16 20:48:57 freenas freenas: USB communication driver 0.31
Jan 16 20:48:57 freenas freenas: Network UPS Tools - UPS driver controller 2.6.2
Jan 16 20:48:57 freenas freenas: Starting nut.
Jan 16 20:48:57 freenas freenas: listening on 127.0.0.1 port 3493
Jan 16 20:48:57 freenas freenas: Connected to UPS [ups]: usbhid-ups-ups
Jan 16 20:48:57 freenas freenas[1765]: Executing: /usr/sbin/service nut_upsmon restart
Jan 16 20:48:57 freenas freenas: nut_upsmon not running? (check /var/db/nut/upsmon.pid).
Jan 16 20:48:57 freenas freenas: Starting nut_upsmon.
Jan 16 20:48:57 freenas freenas: UPS: ups (master) (power value 1)
Jan 16 20:48:57 freenas freenas[1765]: Executing: /usr/sbin/service nut_upslog restart
Jan 16 20:48:57 freenas freenas: nut_upslog not running? (check /var/db/nut/upslog.pid).
Jan 16 20:48:57 freenas freenas: Starting nut_upslog.
Jan 16 20:48:57 freenas freenas[1765]: Executing: /bin/pgrep -F /var/db/nut/upsd.pid upsd
did make anyone the same observation or know a solution for this problem?
regards,
logan54
See the log below:
regards,
logan54
