8.0.4 Release: UPS service does not start
xRaider
FreeNAS-8.0.4-RELEASE-x64. UPS service does not start:
Mar  3 10:05:35 freenas freenas[1755]: Executing: /usr/sbin/service ix-ups quietstart
Mar  3 10:05:36 freenas freenas[1755]: Executing: /usr/sbin/service nut restart
Mar  3 10:05:36 freenas freenas: nut not running? (check /var/db/nut/upsd.pid).
Mar  3 10:05:36 freenas freenas: UPS type: APC Back-UPS (940-0020B/C cable)
Mar  3 10:05:36 freenas freenas: Can't uu_lock cuau0: creat error: Permission denied
Mar  3 10:05:36 freenas freenas: Network UPS Tools - Generic contact-closure UPS driver 1.36 (2.6.2)
Mar  3 10:05:36 freenas freenas: Driver failed to start (exit status=1)
Mar  3 10:05:36 freenas freenas: Network UPS Tools - UPS driver controller 2.6.2
Mar  3 10:05:36 freenas root: /usr/local/etc/rc.d/nut: WARNING: failed precmd routine for nut
Mar  3 10:05:36 freenas freenas: /usr/local/etc/rc.d/nut: WARNING: failed precmd routine for nut
Mar  3 10:05:36 freenas freenas[1755]: Executing: /usr/sbin/service nut_upsmon restart
Mar  3 10:05:36 freenas freenas: nut_upsmon not running? (check /var/db/nut/upsmon.pid).
Mar  3 10:05:36 freenas freenas: Starting nut_upsmon.
Mar  3 10:05:36 freenas freenas: UPS: ups (master) (power value 1)
Mar  3 10:05:36 freenas freenas[1755]: Executing: /usr/sbin/service nut_upslog restart
Mar  3 10:05:36 freenas upsmon[2774]: UPS [ups]: connect failed: Connection failure: Connection refused
Mar  3 10:05:36 freenas upsmon[2774]: Communications with UPS ups lost
Mar  3 10:05:36 freenas freenas: nut_upslog not running? (check /var/db/nut/upslog.pid).
Mar  3 10:05:36 freenas freenas: Starting nut_upslog.
Mar  3 10:05:36 freenas freenas: Warning: initial connect failed: Connection failure: Connection refused
Mar  3 10:05:36 freenas freenas[1755]: Executing: /bin/pgrep -F /var/db/nut/upsd.pid upsd
Mar  3 10:05:41 freenas upsmon[2774]: UPS [ups]: connect failed: Connection failure: Connection refused
Mar  3 10:05:41 freenas upsmon[2774]: UPS ups is unavailable
Mar  3 10:05:46 freenas upsmon[2774]: UPS [ups]: connect failed: Connection failure: Connection refused
Mar  3 10:06:17 freenas last message repeated 6 times
But previous relise FreeNAS-8.0.3-RELEASE-p1-x64 works perfect:
Mar  3 09:46:33 freenas freenas[1682]: Executing: /usr/sbin/service ix-ups quietstart
Mar  3 09:46:33 freenas freenas[1682]: Executing: /usr/sbin/service nut restart
Mar  3 09:46:33 freenas freenas: nut not running? (check /var/db/nut/upsd.pid).
Mar  3 09:46:33 freenas freenas: UPS type: APC Back-UPS (940-0020B/C cable)
Mar  3 09:46:33 freenas freenas: Network UPS Tools - UPS driver controller 2.6.2
Mar  3 09:46:33 freenas freenas: Starting nut.
Mar  3 09:46:33 freenas freenas: listening on 127.0.0.1 port 3493
Mar  3 09:46:33 freenas freenas: Connected to UPS [ups]: genericups-ups
Mar  3 09:46:33 freenas freenas[1682]: Executing: /usr/sbin/service nut_upsmon restart
Mar  3 09:46:33 freenas freenas: nut_upsmon not running? (check /var/db/nut/upsmon.pid).
Mar  3 09:46:33 freenas freenas: Starting nut_upsmon.
Mar  3 09:46:33 freenas freenas: UPS: ups (master) (power value 1)
Mar  3 09:46:33 freenas freenas[1682]: Executing: /usr/sbin/service nut_upslog restart
Mar  3 09:46:33 freenas freenas: nut_upslog not running? (check /var/db/nut/upslog.pid).
Mar  3 09:46:33 freenas freenas: Starting nut_upslog.
Mar  3 09:46:34 freenas freenas[1682]: Executing: /bin/pgrep -F /var/db/nut/upsd.pid upsd
Mar  3 09:46:54 freenas upsmon[7490]: UPS ups on battery
Mar  3 09:46:59 freenas upsmon[7490]: UPS ups on line power
Hardware is the same.
Letni
I had this trouble as well after upgrade.. Ended up completly shutting down my FreeNAS box and powered back on.. UPS service started afterwards..
Take that back.. After looking at the LOGs it appears that i too am having issues with UPS service on 8.0.4.. Using APC 350 USB.. No Love here with 8.0.4... Come' on guys.. fix these stupid bugs!
HAL 9000
Maybe your UPS is connected via USB? Serial connection doesn't work in 8.0.4 due to some device permission problems.
xRaider
My UPS is connected via serial cable:
elpatron
maybe there is a workaround for this problem to get the service running with FN 8.0.4? Any hints?
Bye,
Markus
Hi-Liter
Are you sure the problem just occurs when connected via serial cable?
I have an APC Back-UPS 350 connected via USB and get the following messages when trying to start the ups service:
Output when disconnecting and reconnecting the UPS:
kernel: ugen2.2: <American Power Conversion> at usbus2 (disconnected)
Output when trying to setup and afterwards start ups service (Settings: Identifier: "ups" - Driver: "APC ups 2 Back-UPS Pro USB USB (usbhid-ups)" - Port: "/dev/ugen2.2")
root: Unknown USB device: vendor 0x051d product 0x0002 bus uhub2
freenas[1898]: Executing: /usr/sbin/service ix-ups quietstart
freenas[1898]: Executing: /usr/sbin/service nut restart
freenas: Will not 'restart' nut because nut_enable is NO.
freenas[1898]: Executing: /usr/sbin/service nut_upsmon restart
freenas: Will not 'restart' nut_upsmon because nut_upsmon_enable is NO.
freenas[1898]: Executing: /usr/sbin/service nut_upslog restart
freenas: Will not 'restart' nut_upslog because nut_upslog_enable is NO.
freenas[1898]: Executing: /bin/pgrep -F /var/db/nut/upsd.pid upsd
freenas: Using subdriver: APC HID 0.95
freenas: Network UPS Tools - Generic HID driver 0.35 (2.6.2)
freenas: USB communication driver 0.31
freenas: libusb_get_report: Unknown error
freenas: Can't initialize data from HID UPS
upsmon[2925]: UPS [ups]: connect failed: Connection failure: Connection refused
upsmon[2925]: Communications with UPS ups lost
upsmon[2925]: UPS ups is unavailable
Is this the same issue?
sanddrag
I found ticket #1292 that seems to resolve the issue for me, but it doesn't last through a reboot.
This:
chmod 777 /var/spool/lock
ls -ld /var/spool/lock
works for me, however still three issues:
1. When the shutdown mode is set to "UPS goes on battery" it does not actually initiate shut down until the UPS reaches low battery.
2. No e-mail is sent.
3. How can I make the above permissions fix permanent?
UPS is an APC SmartUPS on a serial connection.
paleoN
You can't it's on /var. However I suppose you could write a sh script that runs on start-up.
shipkiller
This:
sanddrag, I know this is several months since you posted, but did you fix this?
I was able to fix the permissions issue this way and it survives a reboot:
Login as root
MOUNT FILESYSTEM READ/WRITE
mount -uw /
CHANGE THE PERMISSIONS OF THE BASELINE LOCK DIRECTORY
chmod 777 /conf/base/var/spool/lock
MOUNT FILESYSTEM READONLY
mount -wr /
If you already fix your issue, then please disregard..
