When I try to start the UPS Service I get this
Mar 18 01:34:39 FILE-SERVER freenas[1942]: Executing: /usr/sbin/service ix-ups quietstart
Mar 18 01:34:40 FILE-SERVER freenas[1942]: Executing: /usr/sbin/service nut restart
Mar 18 01:34:40 FILE-SERVER freenas: nut not running? (check /var/db/nut/upsd.pid).
Mar 18 01:34:40 FILE-SERVER freenas: Can't uu_lock cuau0: creat error: Permission denied
Mar 18 01:34:40 FILE-SERVER freenas: Network UPS Tools - APC Smart protocol driver 3.0 (2.6.2)
Mar 18 01:34:40 FILE-SERVER freenas: APC command table version 3.0
Mar 18 01:34:40 FILE-SERVER freenas: Driver failed to start (exit status=1)
Mar 18 01:34:40 FILE-SERVER freenas: Network UPS Tools - UPS driver controller 2.6.2
Mar 18 01:34:40 FILE-SERVER root: /usr/local/etc/rc.d/nut: WARNING: failed precmd routine for nut
Mar 18 01:34:40 FILE-SERVER freenas: /usr/local/etc/rc.d/nut: WARNING: failed precmd routine for nut
Mar 18 01:34:40 FILE-SERVER freenas[1942]: Executing: /usr/sbin/service nut_upsmon restart
Mar 18 01:34:40 FILE-SERVER freenas: nut_upsmon not running? (check /var/db/nut/upsmon.pid).
Mar 18 01:34:40 FILE-SERVER freenas: Starting nut_upsmon.
Mar 18 01:34:40 FILE-SERVER freenas: UPS: su1400rmi2u (master) (power value 1)
Mar 18 01:34:40 FILE-SERVER freenas[1942]: Executing: /usr/sbin/service nut_upslog restart
Mar 18 01:34:40 FILE-SERVER upsmon[3244]: UPS [su1400rmi2u]: connect failed: Connection failure: Connection refused
Mar 18 01:34:40 FILE-SERVER upsmon[3244]: Communications with UPS su1400rmi2u lost
Mar 18 01:34:40 FILE-SERVER freenas: nut_upslog not running? (check /var/db/nut/upslog.pid).
Mar 18 01:34:40 FILE-SERVER freenas: Starting nut_upslog.
Mar 18 01:34:40 FILE-SERVER freenas: Warning: initial connect failed: Connection failure: Connection refused
Mar 18 01:34:41 FILE-SERVER freenas[1942]: Executing: /bin/pgrep -F /var/db/nut/upsd.pid upsd
Mar 18 01:34:45 FILE-SERVER upsmon[3244]: UPS [su1400rmi2u]: connect failed: Connection failure: Connection refused
Mar 18 01:34:45 FILE-SERVER upsmon[3244]: UPS su1400rmi2u is unavailable
