I upgraded to FN11 U2 this morning. On reboot my UPS is no longer communicating. Seeing the following on the console log on the web page. Could anyone point me in the right direction to fix this? Thank you in advance.
This is an APC BR1500G Back-UPS Pro using APC ups 2 Back-UPS Pro USB USB (usbhid-ups) before the reboot worked fine.
Getting emails every 15 minutes:
COMMBAD - ups
NOCOMM - ups
FreeNAS-11.0-U2 (e417d8aa5)
COMMBAD - ups
NOCOMM - ups
Jul 21 07:37:50 freenas upsmon[2275]: UPS [ups]: connect failed: Connection failure: Connection refused Jul 21 07:37:51 freenas usb_alloc_device: set address 2 failed (USB_ERR_TIMEOUT, ignored) Jul 21 07:37:51 freenas xhci0: Resetting controller Jul 21 07:37:55 freenas upsmon[2275]: UPS [ups]: connect failed: Connection failure: Connection refused Jul 21 07:38:08 freenas usbd_setup_device_desc: getting device descriptor at addr 2 failed, USB_ERR_TIMEOUT Jul 21 07:38:09 freenas usbd_req_re_enumerate: addr=2, set address failed! (USB_ERR_TIMEOUT, ignored)
Jul 21 16:47:57 freenas upsmon[75787]: upsmon parent: read Jul 21 16:47:57 freenas root: /usr/local/etc/rc.d/nut: WARNING: failed precmd routine for nut Jul 21 16:47:57 freenas upsmon[76643]: UPS [ups]: connect failed: Connection failure: Connection refused Jul 21 16:47:57 freenas upsmon[76643]: Communications with UPS ups lost Jul 21 16:48:02 freenas upsmon[76643]: UPS [ups]: connect failed: Connection failure: Connection refused Jul 21 16:48:02 freenas upsmon[76643]: UPS ups is unavailable Jul 21 16:48:03 freenas usbd_setup_device_desc: getting device descriptor at addr 2 failed, USB_ERR_TIMEOUT Jul 21 16:48:03 freenas ugen0.2: at usbus0 (disconnected) Jul 21 16:48:04 freenas uhub_reattach_port: could not allocate new device Jul 21 16:48:04 freenas uhub0: at usbus0, port 1, addr 1 (disconnected) Jul 21 16:48:04 freenas uhub0: on usbus0 Jul 21 16:48:04 freenas uhub0: 4 ports with 4 removable, self powered Jul 21 16:48:05 freenas usb_alloc_device: set address 2 failed (USB_ERR_TIMEOUT, ignored) Jul 21 16:48:06 freenas xhci0: Resetting controller Jul 21 16:48:07 freenas upsmon[76643]: UPS [ups]: connect failed: Connection failure: Connection refused
