profwalken
- Nov 19, 2013
After latest release has been applied and reboot done srv is missing UPS, In UPS settings port usb is set to auto as I don't know how to find the kind name which is given to UPS usb port used.
If there's a command line I can use, please let me know.
In console these lines don't end to be displayed
Jan 30 17:44:19 SRV-XXXXXX ugen0.3: <EATON Ellipse PRO> at usbus0
Jan 30 17:44:22 SRV-XXXXXX 1 2021-01-30T17:44:22.694136+01:00 SRV-XXXXXX.local upsmon 1521 - - UPS [EATON650@localhost:3493]: connect failed: Connection failure: Connection refused
Jan 30 17:44:27 SRV-XXXXXX 1 2021-01-30T17:44:27.722565+01:00 SRV-XXXXXX.local upsmon 1521 - - UPS [EATON650@localhost:3493]: connect failed: Connection failure: Connection refused
Jan 30 17:44:29 SRV-XXXXXX 1 2021-01-30T17:44:29.233629+01:00 SRV-XXXXXX.local upsmon 1519 - - upsmon parent: read
Jan 30 17:44:30 SRV-XXXXXX interface uhid.1 already present in the KLD 'kernel'!
Jan 30 17:44:30 SRV-XXXXXX linker_load_file: /boot/kernel/uhid.ko - unsupported file type
Jan 30 17:44:30 SRV-XXXXXX interface wmt.1 already present in the KLD 'kernel'!
Jan 30 17:44:30 SRV-XXXXXX linker_load_file: /boot/kernel/wmt.ko - unsupported file type
Jan 30 17:47:38 SRV-XXXXXX 1 2021-01-30T17:47:38.694120+01:00 SRV-XXXXXX.local upsmon 1521 - - UPS [EATON650@localhost:3493]: connect failed: Connection failure: Connection refused
Jan 30 17:47:43 SRV-XXXXXX 1 2021-01-30T17:47:43.755315+01:00 SRV-XXXXXX.local upsmon 1521 - - UPS [EATON650@localhost:3493]: connect failed: Connection failure: Connection refused
Jan 30 17:47:48 SRV-XXXXXX 1 2021-01-30T17:47:48.770344+01:00 SRV-XXXXXX.local upsmon 1521 - - UPS [EATON650@localhost:3493]: connect failed: Connection failure: Connection refused
Jan 30 17:47:49 SRV-XXXXXX 1 2021-01-30T17:47:49.510910+01:00 SRV-XXXXXX.local collectd 1635 - - nut plugin: nut_connect: upscli_connect (localhost, 3493) failed: Connection failure: Connection refused
Jan 30 17:47:53 SRV-XXXXXX 1 2021-01-30T17:47:53.816864+01:00 SRV-XXXXXX.local upsmon 1521 - - UPS [EATON650@localhost:3493]: connect failed: Connection failure: Connection refused
Jan 30 17:47:58 SRV-XXXXXX 1 2021-01-30T17:47:58.825351+01:00 SRV-XXXXXX.local upsmon 1521 - - UPS [EATON650@localhost:3493]: connect failed: Connection failure: Connection refused
Jan 30 17:48:03 SRV-XXXXXX 1 2021-01-30T17:48:03.868375+01:00 SRV-XXXXXX.local upsmon 1521 - - UPS [EATON650@localhost:3493]: connect failed: Connection failure: Connection refused
Other problem with NTP servers
Jan 30 17:47:28 SRV-XXXXXX 1 2021-01-30T17:47:28.638793+01:00 SRV-XXXXXX.local ntpd 1492 - - ntpd 4.2.8p15-a (1): Starting
Jan 30 17:47:28 SRV-XXXXXX 1 2021-01-30T17:47:28.638917+01:00 SRV-XXXXXX.local ntpd 1492 - - Command line: /usr/sbin/ntpd -p /var/db/ntp/ntpd.pid -c /etc/ntp.conf -f /var/db/ntp/ntpd.drift -g
Jan 30 17:47:28 SRV-XXXXXX 1 2021-01-30T17:47:28.638922+01:00 SRV-XXXXXX.local ntpd 1492 - - ----------------------------------------------------
Jan 30 17:47:28 SRV-XXXXXX 1 2021-01-30T17:47:28.638925+01:00 SRV-XXXXXX.local ntpd 1492 - - ntp-4 is maintained by Network Time Foundation,
Jan 30 17:47:28 SRV-XXXXXX 1 2021-01-30T17:47:28.638928+01:00 SRV-XXXXXX.local ntpd 1492 - - Inc. (NTF), a non-profit 501(c)(3) public-benefit
Jan 30 17:47:28 SRV-XXXXXX 1 2021-01-30T17:47:28.638930+01:00 SRV-XXXXXX.local ntpd 1492 - - corporation. Support and training for ntp-4 are
Jan 30 17:47:28 SRV-XXXXXX 1 2021-01-30T17:47:28.638933+01:00 SRV-XXXXXX.local ntpd 1492 - - available at https://www.nwtime.org/support
Jan 30 17:47:28 SRV-XXXXXX 1 2021-01-30T17:47:28.638936+01:00 SRV-XXXXXX.local ntpd 1492 - - ----------------------------------------------------
Jan 30 17:47:28 SRV-XXXXXX 1 2021-01-30T17:47:28.645734+01:00 SRV-XXXXXX.local ntpd 1493 - - restrict: ignoring line 10, address/host '0.freebsd.pool.ntp.org' unusable.
Jan 30 17:47:28 SRV-XXXXXX 1 2021-01-30T17:47:28.646003+01:00 SRV-XXXXXX.local ntpd 1493 - - restrict: ignoring line 11, address/host '1.freebsd.pool.ntp.org' unusable.
Jan 30 17:47:28 SRV-XXXXXX 1 2021-01-30T17:47:28.646216+01:00 SRV-XXXXXX.local ntpd 1493 - - restrict: ignoring line 12, address/host '2.freebsd.pool.ntp.org' unusable.
Any help on this 2 problem really appreciated
