craigyb
- Jun 9, 2013
I built my FreeNas box to replace 4 Thecus 5200 systems which have served me well for many years, but I decided to build one large NAS as opposed to 4 systems.
Anyways, I have been fairly disappointed with the FreeNAS system when I built it with 8.3 P2, when using my PC to connect to the largest of my NAS partitions it could take about 10-15 seconds to get a directory listing, considering it was across 10 spindles this was bad in my mind. I had a lag setup with two interfaces, a bit overkill, but even that didn't help.
I even upgraded my HBA from a SATA 2 to SATA 3 to se if that helped, still not much improvement, system still laggy and taking ages to bring up the contents of the filesystem. Once I did get there the performamce was reasonable. But I also had other issues, my DUNE HD media player didn't like the slow speed of the NAS either and neither did the Mede8er MED600X3D High Definition 3D Multimedia Player.
So last night I upgraded the media pools from the 8.3 installation to the new 9.1.1 version of ZFS using the zfspool upgrade command and suddenly the performance improved massively. The same partition now displays instantly on my PC and the media players seems happy as well. So I would recommend anyone moving from 8.3 to 9.1 to upgrade any pools as well.
