Transmission won't start on 9.1
leszek jaszczak
Ok, I need a hand, I'm out of ideas. I had Transmission and minidlna running succesfully on Freenas 8.3. I upgraded to 9.1 via the gui upgrade. After the upgrade, I wound up deleting and reinstalling my jails and plugins as the migration was troublesome and I was short on time.
Now minidlna works fine, Transmission will not start. The button stays off, I can't change it to on, no log messages I can find.
I have set up my jail IPs correctly I think as minidlna works. I've setup the transmission information as well.
Anyone have any ideas on why a clean install of transmission via the gui would fail to start? Or where to go next troubleshooting?
Thanks all,
Whattteva
Yeah, 9.1 plugins system is pretty buggy. You're lucky you actually GET buttons. I can't even get the plugins to work at all from the GUI so I gave up long ago. I have to do everything manually now and basically I just treat it like a normal FreeBSD system cause it's the only way I could get anything to work at all.
Jason Hamilton
I had an issue with mine where bash was missing from /usr/local/bin within the jail. So a quick cp from the main /usr/bin/bash and I was back in business. Let me know if that helps you.
leszek jaszczak
Ok, I'm back.
Bash was indeed not present in my Jail directory: /mnt/storage/Jail/usr/local/bin directory. I did a cp from the main /usr/local/bin directory, rebooted with no change. Still can't start Transmission.
I'm not sure about the log. The only messages that may be pertinent are as follows:
Aug 22 21:10:25 freenas manage.py: [py.warnings:193] /usr/local/lib/python2.7/site-packages/django/http/request.py:193: DeprecationWarning: HttpRequest.raw_post_data has been deprecated. Use HttpRequest.body instead. warnings.warn('HttpRequest.raw_post_data has been deprecated. Use HttpRequest.body instead.', DeprecationWarning)
Aug 22 21:10:25 freenas manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/warden list -v
Aug 22 21:10:28 freenas manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/warden list -v
A bit beyond me.
Jason Hamilton
I had this issue as well. You might want to try starting transmission by hand. Go into your jail and go to
cd /usr/pbi/transmission-amd64/etc/rc.d/
then
./transmission
and see if it throws any errors your way to help you figure out why its not working. Let me know if I can be of more help.
leszek jaszczak
Ok,
./transmission start yields;
Will not 'start' transmission because transmission_enable is NO.
IfIf I try ./transmission forcestart, I get:
./transmission: WARNING: run_rc_command: cannot run /usr/pbi/transmission-amd64/ bin/transmission-daemon
Whattteva
This means that you need to edit your /etc/rc.conf file and add the line transmission_enable="YES"
After that, try to start the service again.
leszek jaszczak
the /etc/rc.conf file:
transmission_conf_dir="/usr/pbi/transmission-amd64/etc/transmission/home"
transmission_flags="-e /media "
Whattteva
Hm, strange.
Try this:
Try to hit the start button on the FreeNAS gui page.
After it fails, login to the jail via jexec and paste the output of /var/log/messages here.
J
jkh
Guest
9.1 or 9.1.1? 9.1.1 fixes a number of plugin issues. Please try to reproduce this with 9.1.1-RC2.
leszek jaszczak
Hm, I'm really new to some of this. Let's try.
Ok, got it. I don't have a userlog, I found this in Messages.
Aug 22 21:10:06 bit_1 newsyslog[3237]: logfile first created Aug 22 21:10:06 bit_1 syslogd: kernel boot file is /boot/kernel/kernel
Aug 22 21:10:06 bit_1 root: /etc/rc: WARNING: failed to start transmission
Aug 22 21:10:06 bit_1 su: setpriority 'root' (root): Permission denied
Aug 22 21:10:28 bit_1 root: /usr/local/etc/rc.d/transmission: WARNING: failed to
Aug 22 21:23:48 bit_1 root: /usr/local/etc/rc.d/transmission: WARNING: failed to
Aug 23 12:47:02 bit_1 root: /usr/local/etc/rc.d/transmission: WARNING: failed to
Aug 23 13:41:02 bit_1 root: /usr/local/etc/rc.d/transmission: WARNING: failed to
Aug 23 13:42:33 bit_1 root: /usr/local/etc/rc.d/transmission: WARNING: failed to
Aug 23 13:51:33 bit_1 root: /usr/local/etc/rc.d/transmission: WARNING: failed to
leszek jaszczak
hmm, the gui upgrade to 9.1.1 RC2 is stuck on "applying database schema changes" for some time now. That has not happened before.
Should I wait longer or restart?
leszek jaszczak
Update.
I applied 9.1.1 RC2, transmission will not start.
I deleted the plugin/jail and reinstalled it again. Still no luck.
Whattteva
What are the last few lines that appear in /var/log/messages?
leszek jaszczak
10 lines in the log:
Aug 23 16:57:34 bit_1 newsyslog[5874]: logfile first created
Aug 23 16:57:34 bit_1 syslogd: kernel boot file is /boot/kernel/kernel
Aug 23 16:57:35 bit_1 su: setpriority 'root' (root): Permission denied
Aug 23 16:58:51 bit_1 root: /usr/local/etc/rc.d/transmission: WARNING: failed to start transmission
Aug 23 16:59:23 bit_1 root: /usr/local/etc/rc.d/transmission: WARNING: failed to start transmission
Aug 23 16:59:56 bit_1 root: /usr/local/etc/rc.d/transmission: WARNING: failed to start transmission
Aug 23 17:00:05 bit_1 root: /usr/local/etc/rc.d/transmission: WARNING: failed to start transmission
Aug 23 17:00:50 bit_1 last message repeated 2 times
Aug 23 17:02:59 bit_1 last message repeated 4 times
Aug 23 17:03:51 bit_1 last message repeated 2 times
Ok, so this is a process permission problem I think.
MrBerns
Is there a solution for this that doesn't require a reinstallation? I also have the "bit_1 su: setpriority 'root' (root): Permission denied" issue.
