Upgrading to 9.10 Boot Mount Error
gjonm
Hi all,
I've attempted to install the latest stable 9.10 stable, but I'm seeing an error "Unable to mount boot-environment" (see attached screenshot also).
I've carried out a scrub and everything seems healthy (screenshots attached).
I'm inclined to restart, but if there is a problem with the boot drive I don't want to damage it any further.
Any ideas?
Cheers.
SweetAndLow
Sweet'NASty
Looks like freenas is booted up what is the problem?
gjonm
it didn't reboot after the upgrade, and instead I got an error message in the GUI "Error: Unable to mount boot-environment 9.10-STABLE-201606072003"
gjonm
it didn't reboot after the upgrade, and instead I got an error message in the GUI "Error: Unable to mount boot-environment 9.10-STABLE-201606072003". Freenas appears to be running fine, but I can't install the remaining bug fixes in the 9.10 Stable release.
BigDave
FreeNAS Enthusiast
This same thing happened to me about one month ago. The update installed but there was no reboot!
I simply went back to the previous boot environment, and after FreeNAS came back online, made a quick
check to make sure everything was normal.
Taking no chances, I downloaded a fresh iso of the most recent Stable Version and performed a fresh install,
then imported the config file that I saved before attempting the update (I always save a copy before
making ANY changes;))
The whole process took 15min. and was stress free:)
SweetAndLow
Sweet'NASty
Make sure your boot usb has free space and maybe clean up some of the old boot environments you don't need anymore then try again.
gjonm
thanks Dave
