taaangy234
- Dec 7, 2016
Just build my first FreeNAS and got it running like it should for a few days now. I need some suggestion what board I could replace it with that support LGA1155 CPU I currently have. I do want link aggravation, and adding 4 additional drives so some supermicro board comes with 3 Nics and 8 port sata that would saves me from buying additional SAS controller and dual NIC for current setup. I do have 6x8GB ECC Registered 1333 rams that I could use or 6x16GB ECC PC8500. Let me know what do you guys recommends.
I'll be using the NAS mainly for Documents, RAW images for Lightroom/Photoshop editing from the NAS and running NextCloud.
Just myself using the NAS, I do want to improve transfer rate greater than 100mbps tho.
Server Specs:
[root@freenas ~]# iperf -s -w 64k
Server listening on TCP port 5001
TCP window size: 64.0 KByte
[ 7] local 172.18.1.3 port 5001 connected with 172.18.1.13 port 55147
[ ID] Interval Transfer Bandwidth
[ 7] 0.0-10.0 sec 714 MBytes 598 Mbits/sec
Realtek PCI GBE Family Controller (Desktop)
[ 8] local 172.18.1.3 port 5001 connected with 172.18.1.7 port 52086
[ 8] 0.0-10.0 sec 1.09 GBytes 939 Mbits/sec
Intel 82579LM Gigabit Network Connection (Laptop)
[ 7] local 172.18.1.3 port 5001 connected with 172.18.1.7 port 52092
[ 7] 0.0-10.0 sec 1.10 GBytes 940 Mbits/sec
[ 8] local 172.18.1.3 port 5001 connected with 172.18.1.13 port 56208
[ 7] local 172.18.1.3 port 5001 connected with 172.18.1.7 port 52093
[ 8] 0.0-10.0 sec 570 MBytes 478 Mbits/sec
[ 7] 0.0-10.0 sec 821 MBytes 688 Mbits/sec
[ 9] local 172.18.1.3 port 5001 connected with 172.18.1.13 port 56255
[ 9] 0.0-10.0 sec 706 MBytes 592 Mbits/sec
[ 7] local 172.18.1.3 port 5001 connected with 172.18.1.7 port 52095
[ 7] 0.0-10.0 sec 1.10 GBytes 939 Mbits/sec
Server Specs:
- Mobo: Intel DH67GD - BTGD1200025Q
- CPU: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz LGA1155
- 16GB DDR3 Non-ECC
- 380W Antec 80 Plus
- 3x2TB WD Green
- 1x3TB Hitachi
- 1x2TB WD Green (backup)
- on 4 disks Raidz2
- 65GB SSD Cached
- 8GB FreeOSD Boot USB
- Asus Sabortooth X56 I7 920
- 20GB DDR3 1600MHz
- 500GB SSD Samsung EVO
- 2TB WD Blue
- Realtek NIC
- Cox Modem
- Asus RT68 Router
- Cisco Catalyst 3750x 24p Switch
- Fully Cat 6 Media run through the house.
