Hey,
Since the introduction of bhyve into FreeNAS 9.10 and now 9.10.1 I took the opportunity to migrate most of my jails into a VM (FreeBSD 10.3-RELEASE-p7).
I've been checking out the network speed between the host and the guest using iperf and bonnie++ to check the speed of the nfs link between them.
Hardware details:
ASRock C2750d4i, 32GB ECC RAM,
Jails/VMs live on a pair of mirrored 120GB SSDs.
Main pool is 6x3TB WD Reds in RAIDZ2 with a 4TB hot spare.
On the host I'm running:
On the FBSD guest I run:
The results from bonnie++ are largely consistent with the results above. My question is whether these numbers are as good as it gets or is there is there a way to tune the host and guest to get better bandwidth on the connection?
If I've left out any details please free to ask.
Thanks.
Hardware details:
% iperf -s -B 192.168.1.21 ------------------------------------------------------------ Server listening on TCP port 5001 Binding to local address 192.168.1.21 TCP window size: 64.0 KByte (default) ------------------------------------------------------------ [ 4] local 192.168.1.21 port 5001 connected with 192.168.1.40 port 50063 [ ID] Interval Transfer Bandwidth [ 4] 0.0-10.0 sec 755 MBytes 630 Mbits/sec [ 5] local 192.168.1.21 port 5001 connected with 192.168.1.40 port 41277 [ 5] 0.0-10.0 sec 752 MBytes 631 Mbits/sec [ 4] local 192.168.1.21 port 5001 connected with 192.168.1.40 port 60136 [ 4] 0.0-10.0 sec 751 MBytes 629 Mbits/sec
$ iperf -c 192.168.1.21 -p 5001 ------------------------------------------------------------ Client connecting to 192.168.1.21, TCP port 5001 TCP window size: 32.5 KByte (default) ------------------------------------------------------------ [ 3] local 192.168.1.40 port 50063 connected with 192.168.1.21 port 5001 [ ID] Interval Transfer Bandwidth [ 3] 0.0-10.0 sec 755 MBytes 631 Mbits/sec [colmconn@lister ~]$ iperf -c 192.168.1.21 -p 5001 -w 64KB ------------------------------------------------------------ Client connecting to 192.168.1.21, TCP port 5001 TCP window size: 65.0 KByte (WARNING: requested 64.0 KByte) ------------------------------------------------------------ [ 3] local 192.168.1.40 port 41277 connected with 192.168.1.21 port 5001 [ ID] Interval Transfer Bandwidth [ 3] 0.0-10.0 sec 752 MBytes 631 Mbits/sec [colmconn@lister ~]$ iperf -c 192.168.1.21 -p 5001 -w 64KB ------------------------------------------------------------ Client connecting to 192.168.1.21, TCP port 5001 TCP window size: 65.0 KByte (WARNING: requested 64.0 KByte) ------------------------------------------------------------ [ 3] local 192.168.1.40 port 60136 connected with 192.168.1.21 port 5001 [ ID] Interval Transfer Bandwidth [ 3] 0.0-10.0 sec 751 MBytes 630 Mbits/sec
Thanks.
