Upgrading jail does not seem to work
Svenkk4
i have recently upgraded TrueNAS to 12.0-U8. My next step was to upgrade my only jail (i am running nextcloud in it, directly installed not as plugin) too. So i basically used this instructions: https://www.truenas.com/community/threads/how-to-update-upgrade-true-freenas-jails.96640/
i selected 12.3 for the release!
So everything seemed to work but, in the webGUI the jail shows 11.3-RELEASE-p14 in the release field for the jail! But when i open the shell for the jail i am getting greeted with this: FreeBSD 12.2-RELEASE-p12 ec84e0c52a1(HEAD) TRUENAS
also when opening the nextcloud interface and visit the systeminformation view i get the same information (note that i selected 12.3 not 12.2 in the upgrade process)
But when calling: freebsd-version -u in the shell i get 11.3-RELEASE-p14
but uname -a gives the 12.2 stuff
Whats wrong here?
Patrick M. Hausen
uname reports the version of your TrueNAS host, not the one running in the jail.
TrueNAS CORE 12.0-U8 is still based on FreeBSD 12.2. I, personally, would leave the jails at 12.2 + patch levels, rather than outright "leap-frog" them to a 12.3 base. (To keep the server and jails with a common base OS version.)
Have you restarted the jail? What about freebsd-version -k
And what about iocage list
EDIT: You probably created a Clone Jail instead of a Base Jail. I only use Base Jails, and don't mind the extra initial space they require. Updating and upgrading them all is seamless.
pschatz100
I'm pretty certain that jails cannot have a newer version of OS than the Host system. If the Host system is 12.2, then that is the limit for any jails.
