saviodesign
- Apr 7, 2017
Some quick and dirty instructions on How to Update Jails and How to Upgrade Jails.
e.g.
iocage update plex
To do this login via WebGUI.
From the left column navigate to System then Update and update the NAS OS.
Login
iocage console {jailname}
e.g.
iocage console Plex
Stop the service and exit the console
service {servicename} stop
e.g.
service plexmediaserver_plexpass stop
exit
Upgrade target jail
iocage upgrade -r {RELEASE Name} {jailname}
e.g.
iocage upgrade -r 12.3 plex
Note: This will take some time
- Type "y" for yes when inquiries occur
- Type "q" for "quit" when the validation list appears, you may need to type it several times depending on the number of affected items
- Type "y" for yes for any additional inquiries
Note: This may take some time depending on the application version(s) installed and their dependencies
e.g.
iocage restart plex
How to Update & Upgrade
True/FreeNas Jails
True/FreeNas Jails
To Update target jails to Latest Release:
iocage update {jailname}e.g.
iocage update plex
To Upgrade target jails to latest Version:
Note: TrueNas/FreeNas main must be updated prior to upgrading jailTo do this login via WebGUI.
-- Log into target via CLI and Stop Critical Services
Login
e.g.
iocage console Plex
e.g.
exit
-- Begin Upgrade of Jail Version
Upgrade target jail
e.g.
-- Log into target Jail via CLI and Update Packages
pkg update && pkg upgradeNote: This may take some time depending on the application version(s) installed and their dependencies
Exit Console and Restart jail
iocage restart {jailname}e.g.
iocage restart plex
Validate your installations and you’re golden!
