SimpleUser
 - Apr 7, 2022
Hello.
After a zoneminder update, it looks that the jail also needs to be updated based on the following post:
					www.truenas.com
Therefor I tried to update the jail using the command
Unfortunatly I have no ideia what can I do to overcome this problem.
If someone knowns, please provide information.
Thank you
zoneminder fresh install will not run
The plugin starts but when I log onto the web gui it says it is not running. So I logged into the shell of the jail and ran: service zoneminder restart and i get  ld-elf.so.1: /usr/local/lib/perl5/5.32/mach/CORE/libperl.so.5.32: Undefined symbol "strerror_l@FBSD_1.6" After some digging it seems...
root@truenas[~]# iocage upgrade -r 12.3-RELEASE-p5 ZoneMinderJail Snapshotting ZoneMinderJail... Snapshot already exists Updating plugin INDEX... Updating plugin artifact... Cloning git repository Branch 12.2-RELEASE does not exist at https://github.com/freenas/iocage-plugin-zoneminder.git! Using "master" branch for plugin, this may not work with your RELEASE Running upgrade... 12.3-RELEASE is missing 'src.txz', please refetch!
Thank you
