I recently upgraded our storage servers to 11.1-RELEASE. Everything worked fine until the first of Feb. when our bi-monthly scrub started. Scrubs now appear to use all available disk IO and bandwidth regardless of load on the box. In fact, even logging into the box was sluggish and commands would hang so much that I eventually had to cancel the scrub completely. I then upgraded to 11.1-U1 which did the same thing.
I couldn't find any other complaints about this so I had to scrounge around for a fix. I ended up setting
I'm just curious why scrub was changed or if it's something to do with my autotune settings (which where generated on install of 9.10) or something else. Also, do I need to change anything else? It was difficult to find anything about slowing DOWN scrubs since most people want to speed them up.
vfs.zfs.scrub_delay
to 4 and that helped a lot.I'm just curious why scrub was changed or if it's something to do with my autotune settings (which where generated on install of 9.10) or something else. Also, do I need to change anything else? It was difficult to find anything about slowing DOWN scrubs since most people want to speed them up.
