Upgrade Raid1 disks
Stux
Just did some testing:
  • created a pool with two disks in a mirror - call them A and B
  • copied some data onto pool
  • offlined disk B
  • began zpool replace of disk B with a new disk C
  • before resilver was complete, physically disconnected disk A
Reasonably enough, this left the pool faulted and locked.
I could not figure out a way to recover from here. Connecting only disk B gave no results for zpool import. Connecting A and B was no better. Connecting A and C, followed by zpool clear got the pool back, but after resilver, it was empty :eek:
Maybe photorec on B would be a recovery option.
If you split the pool, it would've worked, Ie b would've imported as a separate non-faulted pool to the original. I think that was why I queried if offlining was actually safe.
I think split should be in the GUI.
Not sure how this would affect a multi-vdev pool tho.
Robert Trevellyan
Pony Wrangler
Yes, hence my follow-up post.
If each vdev is a 2-way mirror, you'd end up with two copies of the pool, each with no redundancy. You'd be in better shape if you started out by turning each vdev into a 3-way mirror, but that seems like overkill for growing a pool by replacing disks when you could just use the in-place replacement method. On the other hand, if the goal is to duplicate the pool, it seems like an interesting option.
