diedrichg
- Dec 4, 2012
If I decide to upgrade from 9.10 to Corral one day, I'd like to make it as fresh an experience as possible. I'd flash a clean Corral install and then reset all dataset permissions to "zero".
Q: I have only used Unix permissions on my datasets, folders and files in 9.x. Should I reset all the dataset, folder and files Unix permissions prior to the OS upgrade? What permissions would I set? 777? What would put all my data to a neutral, fresh state?
