Upgrade from 11.1U6 to 11.2 CPU Usage and Temp remains at 0
patrick78
Hi
I just upgraded from 11.1U6 to 11.2. Everything went brilliantly/. Thank you
But CPU Usage remains at 0.
And CPU Temp remains at 0
Other stats are OK
Chris Moore
Hi
Other stats are OK
This appears to be a minor hardware incompatibility. It will probably need some adjustment to the code to get it working fully. If you could submit a support ticket, it would probably get the ball rolling.
Here is the section of the documentation that covers submitting the ticket:
https://www.ixsystems.com/documentation/freenas/11.2/system.html#support
You will need to create an account here first, if you have not already:
https://redmine.ixsystems.com/projects/freenas
Chris Moore
PS. Please post back here with your ticket number.
Ryan_Browne
I have the same problem, but NO reporting is working. CPU, Ethernet, Hard drive temps etc. All show ZERO.
