Upgrade FreeNAS 11.3 -> TrueNAS12: VM does not start
darthvader42
The upgrade from FreeNAS 11.3 to TrueNAS12 worked flawlessly except one thing: I do have an Ubuntu VM which does not start any more.
Upon a manual start via the UI I do get this error message:
File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 137, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self,
File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1206, in _call
File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1110, in run_in_executor
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 977, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/vm.py", line 1595, in start
self.vms[vm['name']].start(vm_data=vm)
File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/vm.py", line 173, in start
raise CallError(
middlewared.service_exception.CallError: [EFAULT] VM will not start as VNC Device: 192.168.178.3:6143 device(s) are not available.
Any idea what went wrong and how this can be fixed?
Samuel Tai
Did your installation change IPs? The exception indicates the VNC device couldn't bind to 192.168.178.3 to offer port 6143.
darthvader42
IP addresses didn't change. The Freenas/truenas box gets 192.168.178.24 statically assigned by the router. Long time ago (>1year) I did use indeed 192.168.178.3 for freenas.
I've changed the VNC device's `bind` setting to `0.0.0.0` - this one was empty before. After that change the VM starts up nicely.
I suspect the culprit was some hidden leftover from a very old configuration manifestated in `bind` being empty.
Thanks for your help. I'll mark this as solved.
Gaspetaahl
I had exactly the same issue, also the bind adress was empty and changing it to 0.0.0.0 fixed the problem. This happened after I updatet from 12.-U1.1 to 12.U2.0
maybe this is a bug or at least an uncoveniet migration that could be addressed in a further update?
peterwyss
I have the same problem, but I can't find a setting for bind.
