I upgraded from the penultimate build from 2014 to the latest available stable build yesterday. After reboot, the webinterface on the System tab displays the following error:
This looks nearly identical to this issue https://bugs.freenas.org/issues/7459.
However, before installing the update, I saw in the list of fixes in the update was this issue; why am I hitting it if it was supposed to be fixed in the update?
my /data/update.failed is also very similar to the one in the bug, but fails in a different stack-
Is this something different from the linked bug, and I should hold state for someone to investigate?
If not, how do I recover?
{"message": "Error: no such column: system_advanced.adv_boot_scrub", "events": [], "error": true}This looks nearly identical to this issue https://bugs.freenas.org/issues/7459.
:~ % cat /data/update.failed ps: cannot mmap corefile ps: empty file: Invalid argument ps: empty file: Invalid argument ps: empty file: Invalid argument ps: empty file: Invalid argument ps: empty file: Invalid argument ps: empty file: Invalid argument ps: empty file: Invalid argument ps: empty file: Invalid argument ps: empty file: Invalid argument ps: empty file: Invalid argument Running migrations for api: - Nothing to migrate. - Loading initial data for api. Installed 0 object(s) from 0 fixture(s) Running migrations for freeadmin: - Nothing to migrate. - Loading initial data for freeadmin. Installed 0 object(s) from 0 fixture(s) Running migrations for support: - Migrating forwards to 0003_auto__add_field_support_support_email. > support:0003_auto__add_field_support_support_email - Loading initial data for support. Installed 0 object(s) from 0 fixture(s) Running migrations for storage: - Migrating forwards to 0052_auto__del_field_task_task_excludesystemdataset. > storage:0051_auto__add_field_task_task_excludesystemdataset > storage:0052_auto__del_field_task_task_excludesystemdataset - Loading initial data for storage. Installed 0 object(s) from 0 fixture(s) Running migrations for tasks: - Migrating forwards to 0004_populate_rsync_delayupdates. > tasks:0003_auto__add_field_rsync_rsync_delayupdates > tasks:0004_populate_rsync_delayupdates - Migration 'tasks:0004_populate_rsync_delayupdates' is marked for no-dry-run. - Loading initial data for tasks. Installed 0 object(s) from 0 fixture(s) Running migrations for network: - Migrating forwards to 0018_auto__add_field_alias_alias_vip__add_field_alias_alias_v4address_b__ad. > network:0016_auto__add_field_interfaces_int_vip__add_field_interfaces_int_vhid__add > network:0017_auto__add_field_globalconfiguration_gc_hostname_b > network:0018_auto__add_field_alias_alias_vip__add_field_alias_alias_v4address_b__ad - Loading initial data for network. Installed 0 object(s) from 0 fixture(s) Running migrations for account: - Migrating forwards to 0023_auto__add_field_bsdusers_bsdusr_microsoft_account. > account:0023_auto__add_field_bsdusers_bsdusr_microsoft_account - Loading initial data for account. Installed 0 object(s) from 0 fixture(s) Running migrations for services: - Migrating forwards to 0183_auto__chg_field_fiberchanneltotarget_fc_target. > services:0158_auto__add_field_afp_afp_srv_homename > services:0159_auto__add_field_nfs_nfs_srv_v4_krb > services:0160_pwencrypt - Migration 'services:0160_pwencrypt' is marked for no-dry-run. > services:0161_auto__chg_field_cifs_cifs_srv_bindip > services:0162_auto__add_field_iscsitargetextent_iscsi_target_extent_rpm > services:0163_auto__add_field_ssh_ssh_host_dsa_key_cert_pub__add_field_ssh_ssh_host_ > services:0164_nfs_srv_v4_krb_fix - Migration 'services:0164_nfs_srv_v4_krb_fix' is marked for no-dry-run. > services:0165_auto__add_field_snmp_snmp_v3__add_field_snmp_snmp_v3_username__add_fie > services:0165_fix_ddns_domains_delimiters - Migration 'services:0165_fix_ddns_domains_delimiters' is marked for no-dry-run. > services:0166_pwencrypt - Migration 'services:0166_pwencrypt' is marked for no-dry-run. ! Error found during real run of migration! Aborting. ! Since you have a database that does not support running ! schema-altering statements in transactions, we have had ! to leave it in an interim state between migrations. ! You *might* be able to recover with: (migration cannot be dry-run; cannot discover commands) ! The South developers regret this has happened, and would ! like to gently persuade you to consider a slightly ! easier-to-deal-with DBMS (one that supports DDL transactions) ! NOTE: The error which caused the migration to fail is further up. Error in migration: services:0166_pwencrypt Traceback (most recent call last): File "/usr/local/www/freenasUI/manage.py", line 42, in <module> execute_from_command_line(sys.argv) File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 399, in execute_from_command_line utility.execute() File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 392, in execute self.fetch_command(subcommand).run_from_argv(self.argv) File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py", line 242, in run_from_argv self.execute(*args, **options.__dict__) File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py", line 285, in execute output = self.handle(*args, **options) File "/usr/local/lib/python2.7/site-packages/south/management/commands/migrate.py", line 111, in handle ignore_ghosts = ignore_ghosts, File "/usr/local/lib/python2.7/site-packages/south/migration/__init__.py", line 220, in migrate_app success = migrator.migrate_many(target, workplan, database) File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 256, in migrate_many result = migrator.__class__.migrate_many(migrator, target, migrations, database) File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 331, in migrate_many result = self.migrate(migration, database) File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 133, in migrate result = self.run(migration, database) File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 114, in run return self.run_migration(migration, database) File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 84, in run_migration migration_function() File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 60, in <lambda> return (lambda: direction(orm)) File "/usr/local/www/freenasUI/../freenasUI/services/migrations/0166_pwencrypt.py", line 29, in forwards do_encrypt(orm['services.iSCSITargetAuthCredential'], 'iscsi_target_auth_secret') File "/usr/local/www/freenasUI/../freenasUI/services/migrations/0166_pwencrypt.py", line 18, in do_encrypt setattr(obj, field, notifier().pwenc_encrypt(getattr(obj, field))) File "/usr/local/www/freenasUI/../freenasUI/middleware/notifier.py", line 5750, in pwenc_encrypt nonce = get_random_bytes(8) File "/usr/local/lib/python2.7/site-packages/Crypto/Random/__init__.py", line 41, in get_random_bytes return _UserFriendlyRNG.get_random_bytes(n) File "/usr/local/lib/python2.7/site-packages/Crypto/Random/_UserFriendlyRNG.py", line 228, in get_random_bytes return _get_singleton().read(n) File "/usr/local/lib/python2.7/site-packages/Crypto/Random/_UserFriendlyRNG.py", line 215, in _get_singleton _singleton = _LockingUserFriendlyRNG() File "/usr/local/lib/python2.7/site-packages/Crypto/Random/_UserFriendlyRNG.py", line 159, in __init__ _UserFriendlyRNG.__init__(self) File "/usr/local/lib/python2.7/site-packages/Crypto/Random/_UserFriendlyRNG.py", line 86, in __init__ self._ec = _EntropyCollector(self._fa) File "/usr/local/lib/python2.7/site-packages/Crypto/Random/_UserFriendlyRNG.py", line 53, in __init__ self._osrng = OSRNG.new() File "/usr/local/lib/python2.7/site-packages/Crypto/Random/OSRNG/posix.py", line 83, in new return DevURandomRNG(*args, **kwargs) File "/usr/local/lib/python2.7/site-packages/Crypto/Random/OSRNG/posix.py", line 44, in __init__ f = open(self.name, "rb", 0) IOError: [Errno 2] No such file or directory: '/dev/urandom' Exception AttributeError: "'DevURandomRNG' object has no attribute 'closed'" in <bound method DevURandomRNG.__del__ of <Crypto.Random.OSRNG.posix.DevURandomRNG object at 0x8106c89d0>> ignored
