I got the following error in data/update.failed after trying to update FreeNAS-9.3-STABLE-201604120241 to 9.10 today:
In most tabs on the GUI, I do not get anything displayed after the system rebooted following the failed update, except
{"error": true, "events": [], "message": "Error: no such column: system_advanced.adv_graphite"}
FATAL ERROR - The following SQL query failed: INSERT INTO "_south_new_storage_encrypteddisk" ("encrypted_volume_id", "id", "encrypted_provider", "encrypted_disk_id") SELECT "encrypted_volume_id", "id", "encrypted_provider", "encrypted_disk_id" FROM "storage_encrypteddisk"; The error was: NOT NULL constraint failed: _south_new_storage_encrypteddisk.encrypted_disk_id Running migrations for api: - Nothing to migrate. - Loading initial data for api. Installed 0 object(s) from 0 fixture(s) Running migrations for freeadmin: - Nothing to migrate. - Loading initial data for freeadmin. Installed 0 object(s) from 0 fixture(s) Running migrations for jails: - Migrating forwards to 0036_templates_to_10_3_release. > jails:0034_templates_to_10 - Migration 'jails:0034_templates_to_10' is marked for no-dry-run. > jails:0035_templates_mtree_to_10 - Migration 'jails:0035_templates_mtree_to_10' is marked for no-dry-run. > jails:0036_templates_to_10_3_release - Migration 'jails:0036_templates_to_10_3_release' is marked for no-dry-run. - Loading initial data for jails. Installed 0 object(s) from 0 fixture(s) Running migrations for vcp: - Nothing to migrate. - Loading initial data for vcp. Installed 0 object(s) from 0 fixture(s) Running migrations for support: - Nothing to migrate. - Loading initial data for support. Installed 0 object(s) from 0 fixture(s) Running migrations for plugins: - Nothing to migrate. - Loading initial data for plugins. Installed 0 object(s) from 0 fixture(s) Running migrations for sharing: - Nothing to migrate. - Loading initial data for sharing. Installed 0 object(s) from 0 fixture(s) Running migrations for tasks: - Nothing to migrate. - Loading initial data for tasks. Installed 0 object(s) from 0 fixture(s) Running migrations for services: - Migrating forwards to 0192_netbiosname_split. > services:0191_auto__add_field_cifs_cifs_srv_netbiosname_b__add_field_cifs_cifs_srv_n > services:0192_netbiosname_split - Migration 'services:0192_netbiosname_split' is marked for no-dry-run. - Loading initial data for services. Installed 0 object(s) from 0 fixture(s) Running migrations for account: - Nothing to migrate. - Loading initial data for account. Installed 0 object(s) from 0 fixture(s) Running migrations for network: - Migrating forwards to 0019_auto__del_field_interfaces_int_carp. > network:0019_auto__del_field_interfaces_int_carp - Loading initial data for network. Installed 0 object(s) from 0 fixture(s) Running migrations for storage: - Migrating forwards to 0058_auto__del_field_disk_id__chg_field_disk_disk_identifier__add_unique_di. > storage:0056_remove_disabled_encryption - Migration 'storage:0056_remove_disabled_encryption' is marked for no-dry-run. > storage:0057_migrate_disk_id_to_identifier - Migration 'storage:0057_migrate_disk_id_to_identifier' is marked for no-dry-run. ! Error found during real run of migration! Aborting. ! Since you have a database that does not support running ! schema-altering statements in transactions, we have had ! to leave it in an interim state between migrations. ! You *might* be able to recover with: (migration cannot be dry-run; cannot discover commands) ! The South developers regret this has happened, and would ! like to gently persuade you to consider a slightly ! easier-to-deal-with DBMS (one that supports DDL transactions) ! NOTE: The error which caused the migration to fail is further up. Error in migration: storage:0057_migrate_disk_id_to_identifier Traceback (most recent call last): File "/usr/local/www/freenasUI/manage.py", line 42, in <module> execute_from_command_line(sys.argv) File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 399, in execute_from_command_line utility.execute() File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 392, in execute self.fetch_command(subcommand).run_from_argv(self.argv) File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py", line 242, in run_from_argv self.execute(*args, **options.__dict__) File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py", line 285, in execute output = self.handle(*args, **options) File "/usr/local/lib/python2.7/site-packages/south/management/commands/migrate.py", line 111, in handle ignore_ghosts = ignore_ghosts, File "/usr/local/lib/python2.7/site-packages/south/migration/__init__.py", line 220, in migrate_app success = migrator.migrate_many(target, workplan, database) File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 256, in migrate_many result = migrator.__class__.migrate_many(migrator, target, migrations, database) File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 331, in migrate_many result = self.migrate(migration, database) File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 133, in migrate result = self.run(migration, database) File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 114, in run return self.run_migration(migration, database) File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 84, in run_migration migration_function() File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 60, in <lambda> return (lambda: direction(orm)) File "/usr/local/www/freenasUI/../freenasUI/storage/migrations/0057_migrate_disk_id_to_identifier.py", line 38, in forwards db.alter_column(u'storage_encrypteddisk', 'encrypted_disk_id', self.gf('django.db.models.fields.CharField')(max_length=100)) File "/usr/local/lib/python2.7/site-packages/south/db/sqlite3.py", line 232, in alter_column name: self._column_sql_for_create(table_name, name, field, explicit_name), File "/usr/local/lib/python2.7/site-packages/south/db/generic.py", line 47, in _cache_clear return func(self, table, *args, **opts) File "/usr/local/lib/python2.7/site-packages/south/db/sqlite3.py", line 113, in _remake_table self._copy_data(table_name, temp_name, renames, added) File "/usr/local/lib/python2.7/site-packages/south/db/sqlite3.py", line 149, in _copy_data self.quote_name(src), File "/usr/local/lib/python2.7/site-packages/south/db/generic.py", line 282, in execute cursor.execute(sql, params) File "/usr/local/lib/python2.7/site-packages/django/db/backends/util.py", line 53, in execute return self.cursor.execute(sql, params) File "/usr/local/lib/python2.7/site-packages/django/db/utils.py", line 99, in __exit__ six.reraise(dj_exc_type, dj_exc_value, traceback) File "/usr/local/lib/python2.7/site-packages/django/db/backends/util.py", line 53, in execute return self.cursor.execute(sql, params) File "/usr/local/www/freenasUI/../freenasUI/freeadmin/sqlite3_ha/base.py", line 372, in execute execute = Database.Cursor.execute(self, query, params) django.db.utils.IntegrityError: NOT NULL constraint failed: _south_new_storage_encrypteddisk.encrypted_disk_id
