Upgrade breaks web interface -- wasn't this fixed?
anRossi
I upgraded from the penultimate build from 2014 to the latest available stable build yesterday. After reboot, the webinterface on the System tab displays the following error:
{"message": "Error: no such column: system_advanced.adv_boot_scrub", "events": [], "error": true}
This looks nearly identical to this issue https://bugs.freenas.org/issues/7459.
However, before installing the update, I saw in the list of fixes in the update was this issue; why am I hitting it if it was supposed to be fixed in the update?
my /data/update.failed is also very similar to the one in the bug, but fails in a different stack-
:~ % cat /data/update.failed
ps: cannot mmap corefile
ps: empty file: Invalid argument
Running migrations for api:
- Nothing to migrate.
 - Loading initial data for api.
Installed 0 object(s) from 0 fixture(s)
Running migrations for freeadmin:
 - Loading initial data for freeadmin.
Running migrations for support:
 - Migrating forwards to 0003_auto__add_field_support_support_email.
 > support:0003_auto__add_field_support_support_email
 - Loading initial data for support.
Running migrations for storage:
 - Migrating forwards to 0052_auto__del_field_task_task_excludesystemdataset.
 > storage:0051_auto__add_field_task_task_excludesystemdataset
 > storage:0052_auto__del_field_task_task_excludesystemdataset
 - Loading initial data for storage.
Running migrations for tasks:
 - Migrating forwards to 0004_populate_rsync_delayupdates.
 > tasks:0003_auto__add_field_rsync_rsync_delayupdates
 > tasks:0004_populate_rsync_delayupdates
 - Migration 'tasks:0004_populate_rsync_delayupdates' is marked for no-dry-run.
 - Loading initial data for tasks.
Running migrations for network:
 - Migrating forwards to 0018_auto__add_field_alias_alias_vip__add_field_alias_alias_v4address_b__ad.
 > network:0016_auto__add_field_interfaces_int_vip__add_field_interfaces_int_vhid__add
 > network:0017_auto__add_field_globalconfiguration_gc_hostname_b
 > network:0018_auto__add_field_alias_alias_vip__add_field_alias_alias_v4address_b__ad
 - Loading initial data for network.
Running migrations for account:
 - Migrating forwards to 0023_auto__add_field_bsdusers_bsdusr_microsoft_account.
 > account:0023_auto__add_field_bsdusers_bsdusr_microsoft_account
 - Loading initial data for account.
Running migrations for services:
 - Migrating forwards to 0183_auto__chg_field_fiberchanneltotarget_fc_target.
 > services:0158_auto__add_field_afp_afp_srv_homename
 > services:0159_auto__add_field_nfs_nfs_srv_v4_krb
 > services:0160_pwencrypt
 - Migration 'services:0160_pwencrypt' is marked for no-dry-run.
 > services:0161_auto__chg_field_cifs_cifs_srv_bindip
 > services:0162_auto__add_field_iscsitargetextent_iscsi_target_extent_rpm
 > services:0163_auto__add_field_ssh_ssh_host_dsa_key_cert_pub__add_field_ssh_ssh_host_
 > services:0164_nfs_srv_v4_krb_fix
 - Migration 'services:0164_nfs_srv_v4_krb_fix' is marked for no-dry-run.
 > services:0165_auto__add_field_snmp_snmp_v3__add_field_snmp_snmp_v3_username__add_fie
 > services:0165_fix_ddns_domains_delimiters
 - Migration 'services:0165_fix_ddns_domains_delimiters' is marked for no-dry-run.
 > services:0166_pwencrypt
 - Migration 'services:0166_pwencrypt' is marked for no-dry-run.
 ! Error found during real run of migration! Aborting.
 ! Since you have a database that does not support running
 ! schema-altering statements in transactions, we have had
 ! to leave it in an interim state between migrations.
! You *might* be able to recover with:  (migration cannot be dry-run; cannot discover commands)
 ! The South developers regret this has happened, and would
 ! like to gently persuade you to consider a slightly
 ! easier-to-deal-with DBMS (one that supports DDL transactions)
 ! NOTE: The error which caused the migration to fail is further up.
Error in migration: services:0166_pwencrypt
  File "/usr/local/www/freenasUI/manage.py", line 42, in <module>
  execute_from_command_line(sys.argv)
  File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 399, in execute_from_command_line
  utility.execute()
  File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 392, in execute
  self.fetch_command(subcommand).run_from_argv(self.argv)
  File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py", line 242, in run_from_argv
  self.execute(*args, **options.__dict__)
  File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py", line 285, in execute
  output = self.handle(*args, **options)
  File "/usr/local/lib/python2.7/site-packages/south/management/commands/migrate.py", line 111, in handle
  ignore_ghosts = ignore_ghosts,
  File "/usr/local/lib/python2.7/site-packages/south/migration/__init__.py", line 220, in migrate_app
  success = migrator.migrate_many(target, workplan, database)
  File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 256, in migrate_many
  result = migrator.__class__.migrate_many(migrator, target, migrations, database)
  File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 331, in migrate_many
  result = self.migrate(migration, database)
  File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 133, in migrate
  result = self.run(migration, database)
  File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 114, in run
  return self.run_migration(migration, database)
  File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 84, in run_migration
  migration_function()
  File "/usr/local/lib/python2.7/site-packages/south/migration/migrators.py", line 60, in <lambda>
  return (lambda: direction(orm))
  File "/usr/local/www/freenasUI/../freenasUI/services/migrations/0166_pwencrypt.py", line 29, in forwards
  do_encrypt(orm['services.iSCSITargetAuthCredential'], 'iscsi_target_auth_secret')
  File "/usr/local/www/freenasUI/../freenasUI/services/migrations/0166_pwencrypt.py", line 18, in do_encrypt
  setattr(obj, field, notifier().pwenc_encrypt(getattr(obj, field)))
  File "/usr/local/www/freenasUI/../freenasUI/middleware/notifier.py", line 5750, in pwenc_encrypt
  nonce = get_random_bytes(8)
  File "/usr/local/lib/python2.7/site-packages/Crypto/Random/__init__.py", line 41, in get_random_bytes
  return _UserFriendlyRNG.get_random_bytes(n)
  File "/usr/local/lib/python2.7/site-packages/Crypto/Random/_UserFriendlyRNG.py", line 228, in get_random_bytes
  return _get_singleton().read(n)
  File "/usr/local/lib/python2.7/site-packages/Crypto/Random/_UserFriendlyRNG.py", line 215, in _get_singleton
  _singleton = _LockingUserFriendlyRNG()
  File "/usr/local/lib/python2.7/site-packages/Crypto/Random/_UserFriendlyRNG.py", line 159, in __init__
  _UserFriendlyRNG.__init__(self)
  File "/usr/local/lib/python2.7/site-packages/Crypto/Random/_UserFriendlyRNG.py", line 86, in __init__
  self._ec = _EntropyCollector(self._fa)
  File "/usr/local/lib/python2.7/site-packages/Crypto/Random/_UserFriendlyRNG.py", line 53, in __init__
  self._osrng = OSRNG.new()
  File "/usr/local/lib/python2.7/site-packages/Crypto/Random/OSRNG/posix.py", line 83, in new
  return DevURandomRNG(*args, **kwargs)
  File "/usr/local/lib/python2.7/site-packages/Crypto/Random/OSRNG/posix.py", line 44, in __init__
  f = open(self.name, "rb", 0)
IOError: [Errno 2] No such file or directory: '/dev/urandom'
Exception AttributeError: "'DevURandomRNG' object has no attribute 'closed'" in <bound method DevURandomRNG.__del__ of <Crypto.Random.OSRNG.posix.DevURandomRNG object at 0x8106c89d0>> ignored
Is this something different from the linked bug, and I should hold state for someone to investigate?
If not, how do I recover?
D
dlavigne
Guest
The referenced bug makes sure that the config was not newer than the upgrade (eg someone upgraded from a nightly to a stable of an earlier date). What build version did you upgrade from, something in the 9.2.1.x series?
anRossi
I saved a backup of my config just before upgrade and I didn't change the default file name.
According to that, I was on FreeNAS-9.3-STABLE-201412240734
I picked my upgrade branch to be 9.3-Stable in the UI (I figure cross-branch upgrades are probably unsupported)
D
dlavigne
Guest
Something didn't pickup in the migration of the config, which is very possible considering it was migrating 8 months worth of changes. If you create a bug report at bugs.freenas.org, post the issue number here. Include the old version, new version, and error messages in the bug report.
anRossi
I opened bug 11244 to track this issue.
https://bugs.freenas.org/issues/11244
One thing I failed to include in the bug is that the scrub of the boot volume keeps failing and sends me mail:
Subject: Cron <root@freenas> /usr/local/libexec/nas/scrub -t freenas-boot
Body:
usage: /usr/local/libexec/nas/scrub [<options>] <pool>
Where options is:
-t Threshold days between scrubs
