I have been using FreeNAS for several years now with great satisfaction, thanks for all the valuable work you do.
This is the first time I bump into something like this and as I made a mention about this mishap on twitter, somebody from FreeNAS suggested me to post about it here.
What happened? I ran the upgrade from 11.0 U4 to 11.1 and some of my NFS shares did not come back up. After some troubleshooting it turns out that the RAID1 (non ZFS, UFS) mirror that I had no longer shows up after boot.
This was a couple of weeks ago and I ran in some snags during troubleshooting so I rolled back to 11.0U4 and everything worked again. (yay!)
So today I deleted the new 11.1 boot partition, then verified the install using the "verify install" button and reran the upgrade. The same thing still happens.
So I looked around, apparently the mirror still exists, but FreeNAS is unaware about it.
In 11.1 I ran the following:
mirror/tuffy is the missing volume and it is there, but not available.
In 11.0U4 there used to also be a line there with "volumes/tuffy"
It now does not show up in /etc/fstab while in 11.0U4 it is in the /etc/fstab file.
Here's my /etc/fstab from 11.0U4:
whereas now in 11.1 it looks like this:
As you see no entry for my UFS mirror anymore.
The /dev/ufs/tuffy node still exists though. I guess I could edit /etc/fstab, but that does not survive a reboot I think, so not sure what to do besides rolling back to 11.0U4 again.
Thanks for any tips,
Wil
# gmirror status Name Status Components mirror/tuffy COMPLETE da4 (ACTIVE) da2 (ACTIVE) mirror/swap0 COMPLETE da7p1 (ACTIVE) da6p1 (ACTIVE) mirror/swap1 COMPLETE da5p1 (ACTIVE) da3p1 (ACTIVE) mirror/swap2 COMPLETE da1p1 (ACTIVE) da0p1 (ACTIVE)
# df -h Filesystem Size Used Avail Capacity Mounted on freenas-boot/ROOT/11.1-RELEASE 3.0G 1.7G 1.3G 57% / devfs 1.0K 1.0K 0B 100% /dev tmpfs 32M 10M 22M 33% /etc tmpfs 4.0M 8.0K 4.0M 0% /mnt tmpfs 11G 23M 11G 0% /var freenas-boot/grub 1.3G 11M 1.3G 1% /boot/grub fdescfs 1.0K 1.0K 0B 100% /dev/fd volumes 3.0T 192K 3.0T 0% /mnt/volumes volumes/bak 800G 112G 688G 14% /mnt/volumes/bak volumes/dat 400G 17G 383G 4% /mnt/volumes/dat volumes/jails 3.0T 192K 3.0T 0% /mnt/volumes/jails volumes/scripts 1.0G 192K 1.0G 0% /mnt/volumes/scripts volumes/.system 3.0T 208K 3.0T 0% /var/db/system volumes/.system/cores 3.0T 791K 3.0T 0% /var/db/system/cores volumes/.system/samba4 3.0T 376K 3.0T 0% /var/db/system/samba4 volumes/.system/syslog-3832181b18e34de7b6f55927b62eb059 3.0T 1.1M 3.0T 0% /var/db/system/syslog-3832181b18e34de7b6f55927b62eb059 volumes/.system/rrd-3832181b18e34de7b6f55927b62eb059 3.0T 192K 3.0T 0% /var/db/system/rrd-3832181b18e34de7b6f55927b62eb059 volumes/.system/configs-3832181b18e34de7b6f55927b62eb059 3.0T 88M 3.0T 0% /var/db/system/configs-3832181b18e34de7b6f55927b62eb059 tmpfs 600M 106M 494M 18% /var/db/collectd/rrd
# cat /etc/fstab freenas-boot/grub /boot/grub zfs rw,noatime 1 0 fdescfs /dev/fd fdescfs rw 0 0 /dev/ufs/tuffy /mnt/tuffy ufs rw,nfsv4acls,late 2 2 /dev/da0p1.eli none swap sw 0 0 /dev/da1p1.eli none swap sw 0 0 /dev/da3p1.eli none swap sw 0 0 /dev/da5p1.eli none swap sw 0 0 /dev/da6p1.eli none swap sw 0 0 /dev/da7p1.eli none swap sw 0 0
# cat /etc/fstab freenas-boot/grub /boot/grub zfs rw,noatime 1 0 fdescfs /dev/fd fdescfs rw 0 0 /dev/mirror/swap0.eli none swap sw 0 0 /dev/mirror/swap1.eli none swap sw 0 0 /dev/mirror/swap2.eli none swap sw 0 0
Wil
