William Yoder
- May 28, 2017
Hi, I've had two boot devices die in less than two weeks on a new FreeNAS install (11.0-Stable). Fortunately, I had a mirror on the boot device both times, but I'm wondering if I did something wrong when I installed FreeNAS.
Can someone please tell me if there is a way to determine if I installed incorrectly? Is it even possible? Or does the FreeNAS installation automatically detect a USB install device and properly set it up as read only? And if I did install incorrectly, can someone please tell me the best course of action to correct it?
I cat'ed /etc/fstab, but it doesn't give much detail:
Thanks very much in advance! Any help is greatly appreciated.
root@freenas03:/ # cat /etc/fstab freenas-boot/grub /boot/grub zfs rw,noatime 1 0 fdescfs /dev/fd fdescfs rw 0 0 /dev/ada0p1.eli none swap sw 0 0 /dev/ada1p1.eli none swap sw 0 0
