- Feb 18, 2014
I have tried to update my Plex jail today. This was originally a warden jail from "years back" and converted to an iocage jail. It's presently showing to be on 10.3.
I followed the update instructions and selected the latest release, but the update failed.
I tried again with a couple more releases "just for fun": 10.4 and 11.1. Both attempts also failed.
Error messages in all cases were identical - see below.
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 128, in main_worker
res = loop.run_until_complete(coro)
File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete
return future.result()
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 88, in _run
return await self._call(f'{service_name}.{method}', serviceobj, methodobj, params=args, job=job)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 81, in _call
return methodobj(*params)
File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 773, in upgrade
IOCUpgrade(conf, release, root_path).upgrade_jail()
File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_upgrade.py", line 116, in upgrade_jail
raise RuntimeError("Error occured, jail not upgraded!")
RuntimeError: Error occured, jail not upgraded!
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.6/site-packages/middlewared/job.py", line 332, in run
await self.future
File "/usr/local/lib/python3.6/site-packages/middlewared/job.py", line 356, in __run_body
rv = await self.middleware._call_worker(self.serviceobj, self.method_name, *self.args, job={'id': self.id})
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1073, in _call_worker
job,
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1004, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 989, in run_in_executor
Any ideas?
await self.future
job,
Any ideas?
