GJSchaller
- Feb 10, 2021
I recenlty was running package updates on my jails, and one of them running Caddy gave me the following message on update:
I followed these steps, but ran into an issue with "service portacl start":
What do I need to do to correct this, so that I can update Caddy to run as www and not as root?
This is in a FreeBSD 13.2-RELEASE-p10 jail, with all packages current as of March 16th, running on TrueNAS-13.0-U6.1
@danb35 - if your creation scripts take care of this already, I can just nuke the jail and rebuild it.
Message from caddy-2.7.6:
It is STRONGLY RECOMMENDED to run Caddy as an unprivileged user, such as
www:www, rather than the current default of root:wheel.
If you have relied upon earlier defaults:
- Use security/portacl-rc to enable privileged port binding:
# pkg install security/portacl-rc
# sysrc portacl_users+=www
# sysrc portacl_user_www_tcp="http https"
# sysrc portacl_user_www_udp="https"
# service portacl enable
# service portacl start
- Stop the server, and update ownership on Caddy runtime files:
# service caddy stop
# chown -R www:www /var/db/caddy /var/log/caddy /var/run/caddy
Other changes may be necessary depending on your exact Caddy
configuration.
- Change the default runtime user, and restart the server:
# sysrc caddy_user=www caddy_group=www
# service caddy start
root@piwigo:~ # service portacl start
kldload: can't load mac_portacl: Operation not permitted
/usr/local/etc/rc.d/portacl: WARNING: Unable to load kernel module mac_portacl
root@piwigo:~ #
