Thank you! It's a case of "no information" to "too much information" I think :)
+ . /etc/rc.subr
+ : 76359
+ export RC_PID
+ [ -n '' ]
+ _rc_subr_loaded=YES
+ SYSCTL=/sbin/sysctl
+ SYSCTL_N='/sbin/sysctl -n'
+ SYSCTL_W=/sbin/sysctl
+ PROTECT=/usr/bin/protect
+ ID=/usr/bin/id
+ IDCMD='if [ -x /usr/bin/id ]; then /usr/bin/id -un; fi'
+ PS='/bin/ps -ww'
+ JID=0
+ rc_service=/usr/local/etc/rc.d/homeassistant
+ _rc_namevarlist='program chroot chdir env flags fib nice user group groups prepend setup'
+ kenv -q rc.debug
+ name=homeassistant
+ rcvar=homeassistant_enable
+ pidfile_child=/var/run/homeassistant/homeassistant.pid
+ pidfile=/var/run/homeassistant/homeassistant_daemon.pid
+ logfile=/var/log/homeassistant.log
+ load_rc_config homeassistant
+ local _name _rcvar_val _var _defval _v _msg _new _d
+ _name=homeassistant
+ false
+ [ -r /etc/defaults/rc.conf ]
+ debug 'Sourcing /etc/defaults/rc.conf'
+ . /etc/defaults/rc.conf
+ : /usr/local
+ rc_info=NO
+ rc_startmsgs=YES
+ rcshutdown_timeout=90
+ early_late_divider=FILESYSTEMS
+ always_force_depends=NO
+ apm_enable=NO
+ apmd_enable=NO
+ apmd_flags=''
+ ddb_enable=NO
+ ddb_config=/etc/ddb.conf
+ devd_enable=YES
+ devd_flags=''
+ devmatch_enable=YES
+ devmatch_blocklist=''
+ kldxref_enable=YES
+ kldxref_clobber=NO
+ kldxref_module_path=''
+ powerd_enable=NO
+ powerd_flags=''
+ tmpmfs=AUTO
+ tmpsize=20m
+ tmpmfs_flags=-S
+ varmfs=AUTO
+ varsize=32m
+ varmfs_flags=-S
+ mfs_type=auto
+ populate_var=AUTO
+ cleanvar_enable=YES
+ var_run_enable=NO
+ var_run_autosave=NO
+ var_run_mtree=/var/db/mtree/BSD.var-run.mtree
+ local_startup=/usr/local/etc/rc.d
+ script_name_sep=' '
+ rc_conf_files='/etc/rc.conf /etc/rc.conf.local'
+ zfs_enable=NO
+ zfskeys_enable=NO
+ zfs_bootonce_activate=NO
+ zpool_reguid=''
+ zfsd_enable=NO
+ gptboot_enable=YES
+ gbde_autoattach_all=NO
+ gbde_devices=NO
+ gbde_attach_attempts=3
+ gbde_lockdir=/etc
+ geli_devices=''
+ geli_groups=''
+ geli_tries=''
+ geli_default_flags=''
+ geli_autodetach=YES
+ root_rw_mount=YES
+ root_hold_delay=30
+ fsck_flags=-p
+ fsck_y_enable=NO
+ fsck_y_flags='-T ffs:-R -T ufs:-R'
+ background_fsck=YES
+ background_fsck_delay=60
+ growfs_enable=NO
+ growfs_swap_size=''
+ netfs_types='nfs:NFS smbfs:SMB'
+ extra_netfs_types=NO
+ hostname=''
+ hostid_enable=YES
+ hostid_file=/etc/hostid
+ hostid_uuidgen_flags=-r
+ machine_id_file=/etc/machine-id
+ nisdomainname=NO
+ dhclient_program=/sbin/dhclient
+ dhclient_flags=''
+ background_dhclient=NO
+ synchronous_dhclient=NO
+ defaultroute_delay=30
+ defaultroute_carrier_delay=5
+ netif_enable=YES
+ netif_ipexpand_max=2048
+ wpa_supplicant_program=/usr/sbin/wpa_supplicant
+ wpa_supplicant_flags=-s
+ wpa_supplicant_conf_file=/etc/wpa_supplicant.conf
+ firewall_enable=NO
+ firewall_script=/etc/rc.firewall
+ firewall_type=UNKNOWN
+ firewall_quiet=NO
+ firewall_logging=NO
+ firewall_logif=NO
+ firewall_flags=''
+ firewall_coscripts=''
+ firewall_client_net=192.0.2.0/24
+ firewall_simple_iif=em1
+ firewall_simple_inet=192.0.2.16/28
+ firewall_simple_oif=em0
+ firewall_simple_onet=192.0.2.0/28
+ firewall_myservices=''
+ firewall_allowservices=''
+ firewall_trusted=''
+ firewall_logdeny=NO
+ firewall_nologports='135-139,445 1026,1027 1433,1434'
+ firewall_nat_enable=NO
+ firewall_nat_interface=''
+ firewall_nat_flags=''
+ firewall_nat64_enable=NO
+ firewall_nptv6_enable=NO
+ firewall_pmod_enable=NO
+ dummynet_enable=NO
+ ipfw_netflow_enable=NO
+ ip_portrange_first=NO
+ ip_portrange_last=NO
+ ike_enable=NO
+ ike_program=/usr/local/sbin/isakmpd
+ ike_flags=''
+ ipsec_enable=NO
+ ipsec_file=/etc/ipsec.conf
+ natd_program=/sbin/natd
+ natd_enable=NO
+ natd_interface=''
+ natd_flags=''
+ ipfilter_enable=NO
+ ipfilter_program=/sbin/ipf
+ ipfilter_rules=/etc/ipf.rules
+ ipfilter_flags=''
+ ippool_enable=NO
+ ippool_program=/sbin/ippool
+ ippool_rules=/etc/ippool.tables
+ ippool_flags=''
+ ipnat_enable=NO
+ ipnat_program=/sbin/ipnat
+ ipnat_rules=/etc/ipnat.rules
+ ipnat_flags=''
+ ipmon_enable=NO
+ ipmon_program=/sbin/ipmon
+ ipmon_flags=-Ds
+ ipfs_enable=NO
+ ipfs_program=/sbin/ipfs
+ ipfs_flags=''
+ pf_enable=NO
+ pf_rules=/etc/pf.conf
+ pf_program=/sbin/pfctl
+ pf_flags=''
+ pf_fallback_rules_enable=NO
+ pf_fallback_rules='block drop log all'
+ pf_fallback_rules_file=/etc/pf-fallback.conf
+ pflog_enable=NO
+ pflog_logfile=/var/log/pflog
+ pflog_program=/sbin/pflogd
+ pflog_flags=''
+ ftpproxy_enable=NO
+ ftpproxy_flags=''
+ pfsync_enable=NO
+ pfsync_syncdev=''
+ pfsync_syncpeer=''
+ pfsync_ifconfig=''
+ tcp_extensions=YES
+ log_in_vain=0
+ tcp_keepalive=YES
+ tcp_drop_synfin=NO
+ icmp_drop_redirect=auto
+ icmp_log_redirect=NO
+ network_interfaces=auto
+ cloned_interfaces=''
+ sppp_interfaces=''
+ ppp_enable=NO
+ ppp_program=/usr/sbin/ppp
+ ppp_mode=auto
+ ppp_nat=YES
+ ppp_profile=papchap
+ ppp_user=root
+ hostapd_program=/usr/sbin/hostapd
+ hostapd_enable=NO
+ syslogd_enable=YES
+ syslogd_program=/usr/sbin/syslogd
+ syslogd_flags=-s
+ syslogd_oomprotect=YES
+ altlog_proglist=''
+ inetd_enable=NO
+ inetd_program=/usr/sbin/inetd
+ inetd_flags='-wW -C 60'
+ iscsid_enable=NO
+ iscsictl_enable=NO
+ iscsictl_flags=-Aa
+ hastd_enable=NO
+ hastd_program=/sbin/hastd
+ hastd_flags=''
+ ctld_enable=NO
+ local_unbound_enable=NO
+ local_unbound_tls=NO
+ blacklistd_enable=NO
+ blacklistd_flags=''
+ resolv_enable=YES
+ kdc_enable=NO
+ kdc_program=/usr/libexec/kdc
+ kdc_flags=''
+ kadmind_enable=NO
+ kadmind_program=/usr/libexec/kadmind
+ kpasswdd_enable=NO
+ kpasswdd_program=/usr/libexec/kpasswdd
+ kfd_enable=NO
+ kfd_program=/usr/libexec/kfd
+ kfd_flags=''
+ ipropd_master_enable=NO
+ ipropd_master_program=/usr/libexec/ipropd-master
+ ipropd_master_flags=''
+ ipropd_master_keytab=/etc/krb5.keytab
+ ipropd_master_slaves=''
+ ipropd_slave_enable=NO
+ ipropd_slave_program=/usr/libexec/ipropd-slave
+ ipropd_slave_flags=''
+ ipropd_slave_keytab=/etc/krb5.keytab
+ ipropd_slave_master=''
+ gssd_enable=NO
+ gssd_program=/usr/sbin/gssd
+ gssd_flags=''
+ rwhod_enable=NO
+ rwhod_flags=''
+ rarpd_enable=NO
+ rarpd_flags=-a
+ bootparamd_enable=NO
+ bootparamd_flags=''
+ pppoed_enable=NO
+ pppoed_provider='*'
+ pppoed_flags='-P /var/run/pppoed.pid'
+ pppoed_interface=em0
+ sshd_enable=NO
+ sshd_program=/usr/sbin/sshd
+ sshd_flags=''
+ ftpd_enable=NO
+ ftpd_program=/usr/libexec/ftpd
+ ftpd_flags=''
+ autofs_enable=NO
+ automount_flags=''
+ automountd_flags=''
+ autounmountd_flags=''
+ nfs_client_enable=NO
+ nfs_access_cache=60
+ nfs_server_enable=NO
+ nfs_server_flags='-u -t'
+ nfs_server_managegids=NO
+ nfs_server_maxio=131072
+ mountd_enable=NO
+ mountd_flags='-r -S'
+ weak_mountd_authentication=NO
+ nfs_reserved_port_only=NO
+ nfs_bufpackets=''
+ rpc_lockd_enable=NO
+ rpc_lockd_flags=''
+ rpc_statd_enable=NO
+ rpc_statd_flags=''
+ rpcbind_enable=NO
+ rpcbind_program=/usr/sbin/rpcbind
+ rpcbind_flags=''
+ rpc_ypupdated_enable=NO
+ keyserv_enable=NO
+ keyserv_flags=''
+ nfsv4_server_enable=NO
+ nfsv4_server_only=NO
+ nfscbd_enable=NO
+ nfscbd_flags=''
+ nfsuserd_enable=NO
+ nfsuserd_flags=''
+ tlsclntd_enable=NO
+ tlsclntd_flags=''
+ tlsservd_enable=NO
+ tlsservd_flags=''
+ ntpdate_enable=NO
+ ntpdate_program=/usr/sbin/ntpdate
+ ntpdate_flags=-b
+ ntpdate_config=/etc/ntp.conf
+ ntpdate_hosts=''
+ ntpd_enable=NO
+ ntpd_program=/usr/sbin/ntpd
+ ntpd_config=/etc/ntp.conf
+ ntpd_sync_on_start=NO
+ ntpd_flags=''
+ ntp_src_leapfile=/etc/ntp/leap-seconds
+ ntp_db_leapfile=/var/db/ntpd.leap-seconds.list
+ ntp_leapfile_sources=https://hpiers.obspm.fr/iers/bul/bulc/ntp/leap-seconds.list
+ ntp_leapfile_fetch_opts=-mq
+ ntp_leapfile_expiry_days=30
+ ntp_leapfile_fetch_verbose=NO
+ nis_client_enable=NO
+ nis_client_flags=''
+ nis_ypset_enable=NO
+ nis_ypset_flags=''
+ nis_server_enable=NO
+ nis_server_flags=''
+ nis_ypxfrd_enable=NO
+ nis_ypxfrd_flags=''
+ nis_yppasswdd_enable=NO
+ nis_yppasswdd_flags=''
+ nis_ypldap_enable=NO
+ nis_ypldap_flags=''
+ bsnmpd_enable=NO
+ bsnmpd_flags=''
+ defaultrouter=NO
+ static_arp_pairs=''
+ static_ndp_pairs=''
+ static_routes=''
+ gateway_enable=NO
+ routed_enable=NO
+ routed_program=/sbin/routed
+ routed_flags=-q
+ arpproxy_all=NO
+ forward_sourceroute=NO
+ accept_sourceroute=NO
+ hcsecd_enable=NO
+ hcsecd_config=/etc/bluetooth/hcsecd.conf
+ sdpd_enable=NO
+ sdpd_control=/var/run/sdp
+ sdpd_groupname=nobody
+ sdpd_username=nobody
+ bthidd_enable=NO
+ bthidd_config=/etc/bluetooth/bthidd.conf
+ bthidd_hids=/var/db/bthidd.hids
+ bthidd_evdev_support=AUTO
+ rfcomm_pppd_server_enable=NO
+ rfcomm_pppd_server_profile='one two'
+ rfcomm_pppd_server_one_channel=1
+ rfcomm_pppd_server_two_channel=3
+ ubthidhci_enable=NO
+ netwait_enable=NO
+ netwait_timeout=60
+ netwait_if_timeout=30
+ icmp_bmcastecho=NO
+ ipv6_network_interfaces=auto
+ ipv6_activate_all_interfaces=NO
+ ipv6_defaultrouter=NO
+ ipv6_static_routes=''
+ ipv6_gateway_enable=NO
+ ipv6_cpe_wanif=NO
+ ipv6_privacy=NO
+ route6d_enable=NO
+ route6d_program=/usr/sbin/route6d
+ route6d_flags=''
+ ipv6_default_interface=NO
+ rtsol_flags=-i
+ rtsold_enable=NO
+ rtsold_flags='-a -i'
+ rtadvd_enable=NO
+ rtadvd_interfaces=''
+ stf_interface_ipv4addr=''
+ stf_interface_ipv4plen=0
+ stf_interface_ipv6_ifid=0:0:0:1
+ stf_interface_ipv6_slaid=0000
+ ipv6_ipv4mapping=NO
+ ipv6_ipfilter_rules=/etc/ipf6.rules
+ ip6addrctl_enable=YES
+ ip6addrctl_verbose=NO
+ ip6addrctl_policy=AUTO
+ keyboard=''
+ keymap=NO
+ keyrate=NO
+ keybell=NO
+ keychange=NO
+ cursor=NO
+ scrnmap=NO
+ font8x16=NO
+ font8x14=NO
+ font8x8=NO
+ blanktime=300
+ saver=NO
+ moused_nondefault_enable=YES
+ moused_enable=NO
+ moused_type=auto
+ moused_port=/dev/psm0
+ moused_flags=''
+ mousechar_start=NO
+ allscreens_flags=''
+ allscreens_kbdflags=''
+ mta_start_script=/etc/rc.sendmail
+ sendmail_enable=NO
+ sendmail_pidfile=/var/run/sendmail.pid
+ sendmail_procname=/usr/sbin/sendmail
+ sendmail_flags='-L sm-mta -bd -q30m'
+ sendmail_cert_create=YES
+ sendmail_submit_enable=YES
+ sendmail_submit_flags='-L sm-mta -bd -q30m -ODaemonPortOptions=Addr=localhost'
+ sendmail_outbound_enable=YES
+ sendmail_outbound_flags='-L sm-queue -q30m'
+ sendmail_msp_queue_enable=YES
+ sendmail_msp_queue_flags='-L sm-msp-queue -Ac -q30m'
+ sendmail_rebuild_aliases=NO
+ auditd_enable=NO
+ auditd_program=/usr/sbin/auditd
+ auditd_flags=''
+ auditdistd_enable=NO
+ auditdistd_program=/usr/sbin/auditdistd
+ auditdistd_flags=''
+ cron_enable=YES
+ cron_program=/usr/sbin/cron
+ cron_dst=YES
+ cron_flags=''
+ cfumass_enable=NO
+ cfumass_dir=/var/cfumass
+ cfumass_image=/var/tmp/cfumass.img
+ lpd_enable=NO
+ lpd_program=/usr/sbin/lpd
+ lpd_flags=''
+ nscd_enable=NO
+ chkprintcap_enable=NO
+ chkprintcap_flags=-d
+ dumpdev=NO
+ dumpon_flags=''
+ dumpdir=/var/crash
+ savecore_enable=YES
+ savecore_flags='-m 10'
+ service_delete_empty=NO
+ crashinfo_enable=YES
+ crashinfo_program=/usr/sbin/crashinfo
+ quota_enable=NO
+ check_quotas=YES
+ quotaon_flags=-a
+ quotaoff_flags=-a
+ quotacheck_flags=-a
+ accounting_enable=NO
+ firstboot_sentinel=/firstboot
+ sysvipc_enable=NO
+ linux_enable=NO
+ linux_mounts_enable=YES
+ clear_tmp_enable=NO
+ clear_tmp_X=YES
+ ldconfig_insecure=NO
+ ldconfig_paths='/usr/lib/compat /usr/local/lib /usr/local/lib/compat/pkg'
+ ldconfig32_paths='/usr/lib32 /usr/lib32/compat'
+ ldconfigsoft_paths='/usr/libsoft /usr/libsoft/compat /usr/local/libsoft'
+ ldconfig_local_dirs=/usr/local/libdata/ldconfig
+ ldconfig_local32_dirs=/usr/local/libdata/ldconfig32
+ ldconfig_localsoft_dirs=/usr/local/libdata/ldconfigsoft
+ kern_securelevel_enable=NO
+ kern_securelevel=-1
+ update_motd=YES
+ entropy_boot_file=/boot/entropy
+ entropy_file=/entropy
+ entropy_dir=/var/db/entropy
+ entropy_save_sz=4096
+ entropy_save_num=8
+ harvest_mask=511
+ osrelease_enable=YES
+ osrelease_file=/var/run/os-release
+ osrelease_perms=444
+ dmesg_enable=YES
+ watchdogd_enable=NO
+ watchdogd_flags=''
+ watchdogd_timeout=''
+ watchdogd_shutdown_timeout=''
+ devfs_rulesets='/etc/defaults/devfs.rules /etc/devfs.rules'
+ devfs_system_ruleset=''
+ devfs_set_rulesets=''
+ devfs_load_rulesets=YES
+ performance_cx_lowest=NONE
+ performance_cpu_freq=NONE
+ economy_cx_lowest=Cmax
+ economy_cpu_freq=NONE
+ virecover_enable=YES
+ ugidfw_enable=NO
+ bsdextended_script=/etc/rc.bsdextended
+ newsyslog_enable=YES
+ newsyslog_flags=-CN
+ mixer_enable=YES
+ opensm_enable=NO
+ rctl_enable=YES
+ rctl_rules=/etc/rctl.conf
+ iovctl_files=''
+ jail_enable=NO
+ jail_conf=/etc/jail.conf
+ jail_confwarn=YES
+ jail_parallel_start=NO
+ jail_list=''
+ jail_reverse_stop=NO
+ [ -z '' ]
+ source_rc_confs_defined=yes
+ [ -r /etc/defaults/vendor.conf ]
+ source_rc_confs
+ local i sourced_files
+ sourced_files=:/etc/rc.conf:
+ [ -r /etc/rc.conf ]
+ . /etc/rc.conf
+ cron_flags=' -J 15'
+ sendmail_submit_enable=NO
+ sendmail_outbound_enable=NO
+ sendmail_msp_queue_enable=NO
+ syslogd_flags='-c -ss'
+ ipv6_activate_all_interfaces=YES
+ ifconfig_epair0b=SYNCDHCP
+ homeassistant_enable=YES
+ sourced_files=:/etc/rc.conf::/etc/rc.conf.local:
+ [ -r /etc/rc.conf.local ]
+ _rc_conf_loaded=true
+ [ -n homeassistant ]
+ _d=/etc
+ [ -f /etc/rc.conf.d/homeassistant ]
+ [ -d /etc/rc.conf.d/homeassistant ]
+ _d=/usr/local/etc
+ [ -f /usr/local/etc/rc.conf.d/homeassistant ]
+ [ -d /usr/local/etc/rc.conf.d/homeassistant ]
+ eval '_defval=$homeassistant_enable_defval'
+ _defval=''
+ [ -n '' ]
+ : YES
+ : homeassistant
+ : homeassistant
+ : /home/homeassistant/.homeassistant
+ : /usr/local/share/homeassistant
+ : 1
+ command=/usr/sbin/daemon
+ start_precmd=homeassistant_prestart
+ start_postcmd=homeassistant_poststart
+ restart_precmd=homeassistant_prerestart
+ status_cmd=homeassistant_status
+ stop_postcmd=homeassistant_postcmd
+ run_rc_command start
+ _return=0
+ rc_arg=start
+ [ -z homeassistant ]
+ shift 1
+ rc_extra_args=''
+ _rc_prefix=''
+ eval '_override_command=$homeassistant_program'
+ _override_command=''
+ _keywords='start stop restart rcvar enable disable delete enabled describe extracommands '
+ rc_pid=''
+ _pidcmd=''
+ _procname=/usr/sbin/daemon
+ [ -n /usr/sbin/daemon ]
+ [ -n /var/run/homeassistant/homeassistant_daemon.pid ]
+ _pidcmd='rc_pid=$(check_pidfile /var/run/homeassistant/homeassistant_daemon.pid /usr/sbin/daemon )'
+ _keywords='start stop restart rcvar enable disable delete enabled describe extracommands status poll'
+ [ -z start ]
+ [ start '=' enabled ]
+ [ -n '' ]
+ eval 'rc_flags=$homeassistant_flags'
+ rc_flags=''
+ eval '_chdir=$homeassistant_chdir' '_chroot=$homeassistant_chroot' '_nice=$homeassistant_nice' '_user=$homeassistant_user' '_group=$homeassistant_group' '_groups=$homeassistant_groups' '_fib=$homeassistant_fib' '_env=$homeassistant_env' '_prepend=$homeassistant_prepend' '_login_class=${homeassistant_login_class:-daemon}' '_limits=$homeassistant_limits' '_oomprotect=$homeassistant_oomprotect' '_setup=$homeassistant_setup' '_env_file=$homeassistant_env_file' '_umask=$homeassistant_umask'
+ _chdir='' _chroot='' _nice='' _user=homeassistant _group=homeassistant _groups='' _fib='' _env='' _prepend='' _login_class=daemon _limits='' _oomprotect='' _setup='' _env_file='' _umask=''
+ [ -n '' ]
+ eval if [ -x /usr/bin/id '];' then /usr/bin/id '-un;' fi
+ [ -x /usr/bin/id ]
+ /usr/bin/id -un
+ [ homeassistant '=' root ]
+ [ -z '' ]
+ eval 'rc_pid=$(check_pidfile' /var/run/homeassistant/homeassistant_daemon.pid /usr/sbin/daemon ')'
+ check_pidfile /var/run/homeassistant/homeassistant_daemon.pid /usr/sbin/daemon
+ _pidfile=/var/run/homeassistant/homeassistant_daemon.pid
+ _interpreter=''
+ [ -z /var/run/homeassistant/homeassistant_daemon.pid -o -z /usr/sbin/daemon ]
+ [ ! -f /var/run/homeassistant/homeassistant_daemon.pid ]
+ read _pid _junk
+ [ -z 71942 ]
+ _find_processes /usr/sbin/daemon . '-p 71942'
+ [ 3 -ne 3 ]
+ _interpreter=.
+ _psargs='-p 71942'
+ _pref=''
+ _procnamebn=daemon
+ _fp_args='_arg0 _argv'
+ _fp_match=$'case "$_arg0" in
\t\t $_procname|$_procnamebn|${_procnamebn}:|"(${_procnamebn})"|"[${_procnamebn}]")'
+ _proccheck=$'\t\t/bin/ps -ww 2>/dev/null -o pid= -o jid= -o command= -p 71942 |
\t\twhile read _npid _jid _arg0 _argv; do
\t\t\tcase "$_arg0" in
\t\t\t\tif [ "$JID" -eq "$_jid" ];
\t\t\t\tthen echo -n "$_pref$_npid";
\t\t\t\t_pref=" ";
\t\t\t\tfi
\t\t\t\t;;
\t\t\tesac
\t\tdone'
+ eval /bin/ps -ww '2>/dev/null' -o 'pid=' -o 'jid=' -o 'command=' -p 71942 '|' while read _npid _jid _arg0 '_argv;' do case '"$_arg0"' in '$_procname|$_procnamebn|${_procnamebn}:|"(${_procnamebn})"|"[${_procnamebn}]")' if [ '"$JID"' -eq '"$_jid"' '];' then echo -n '"$_pref$_npid";' '_pref="' '";' fi ';;' esac done
+ /bin/ps -ww -o 'pid=' -o 'jid=' -o 'command=' -p 71942
+ read _npid _jid _arg0 _argv
+ rc_pid=''
+ [ start '!=' start ]
+ [ -n homeassistant_enable -a start '!=' rcvar -a start '!=' stop -a start '!=' delete -a start '!=' enable -a start '!=' describe -a start '!=' status ]
+ checkyesno homeassistant_enable
+ eval '_value=$homeassistant_enable'
+ _value=YES
+ debug 'checkyesno: homeassistant_enable is set to YES.'
+ return 0
+ [ start '=' start -a -z '' -a -n '' ]
+ eval '_cmd=$start_cmd' '_precmd=$start_precmd' '_postcmd=$start_postcmd'
+ _cmd='' _precmd=homeassistant_prestart _postcmd=homeassistant_poststart
+ [ -n '' ]
+ [ ! -x /usr/sbin/daemon ]
+ _run_rc_precmd
+ check_required_before start
+ local _f
+ return 0
+ [ -n homeassistant_prestart ]
+ debug 'run_rc_command: start_precmd: homeassistant_prestart '
+ eval 'homeassistant_prestart '
+ homeassistant_prestart
+ install -g homeassistant -m 664 -o homeassistant -- /dev/null /var/log/homeassistant.log
+ install -g homeassistant -m 664 -o homeassistant -- /dev/null /var/run/homeassistant/homeassistant_daemon.pid
+ install -g homeassistant -m 664 -o homeassistant -- /dev/null /var/run/homeassistant/homeassistant.pid
+ [ ! -d /home/homeassistant/.homeassistant ]
+ HA_CMD=/usr/local/share/homeassistant/bin/hass
+ HA_ARGS='--ignore-os-check --config /home/homeassistant/.homeassistant'
+ [ -n '' ]
+ [ -n '' ]
+ rc_flags='-f -o /var/log/homeassistant.log -P /var/run/homeassistant/homeassistant_daemon.pid -p /var/run/homeassistant/homeassistant.pid -R 1 /usr/local/share/homeassistant/bin/hass --ignore-os-check --config /home/homeassistant/.homeassistant'
+ echo -f -o /var/log/homeassistant.log -P /var/run/homeassistant/homeassistant_daemon.pid -p /var/run/homeassistant/homeassistant.pid -R 1 /usr/local/share/homeassistant/bin/hass --ignore-os-check --config /home/homeassistant/.homeassistant
+ _return=0
+ [ 0 -ne 0 ]
+ check_required_after start
+ local _f _args
+ return 0
+ return 0
+ startmsg 'Starting homeassistant.'
+ check_startmsgs
+ [ -n '' ]
+ return 0
+ echo 'Starting homeassistant.'
+ [ -n '' ]
+ _cd=''
+ _doit='/usr/sbin/daemon -f -o /var/log/homeassistant.log -P /var/run/homeassistant/homeassistant_daemon.pid -p /var/run/homeassistant/homeassistant.pid -R 1 /usr/local/share/homeassistant/bin/hass --ignore-os-check --config /home/homeassistant/.homeassistant '
+ _doit=$'su -m homeassistant -c \'sh -c "/usr/sbin/daemon -f -o /var/log/homeassistant.log -P /var/run/homeassistant/homeassistant_daemon.pid -p /var/run/homeassistant/homeassistant.pid -R 1 /usr/local/share/homeassistant/bin/hass --ignore-os-check --config /home/homeassistant/.homeassistant "\''
+ [ -n '' ]
+ [ -n '' ]
+ [ -n '' ]
+ _doit=$' limits -C daemon su -m homeassistant -c \'sh -c "/usr/sbin/daemon -f -o /var/log/homeassistant.log -P /var/run/homeassistant/homeassistant_daemon.pid -p /var/run/homeassistant/homeassistant.pid -R 1 /usr/local/share/homeassistant/bin/hass --ignore-os-check --config /home/homeassistant/.homeassistant "\''
+ _run_rc_doit $' limits -C daemon su -m homeassistant -c \'sh -c "/usr/sbin/daemon -f -o /var/log/homeassistant.log -P /var/run/homeassistant/homeassistant_daemon.pid -p /var/run/homeassistant/homeassistant.pid -R 1 /usr/local/share/homeassistant/bin/hass --ignore-os-check --config /home/homeassistant/.homeassistant "\''
+ local _m
+ debug $'run_rc_command: doit: limits -C daemon su -m homeassistant -c \'sh -c "/usr/sbin/daemon -f -o /var/log/homeassistant.log -P /var/run/homeassistant/homeassistant_daemon.pid -p /var/run/homeassistant/homeassistant.pid -R 1 /usr/local/share/homeassistant/bin/hass --ignore-os-check --config /home/homeassistant/.homeassistant "\''
+ umask
+ _m=0022
+ eval $' limits -C daemon su -m homeassistant -c \'sh -c "/usr/sbin/daemon -f -o /var/log/homeassistant.log -P /var/run/homeassistant/homeassistant_daemon.pid -p /var/run/homeassistant/homeassistant.pid -R 1 /usr/local/share/homeassistant/bin/hass --ignore-os-check --config /home/homeassistant/.homeassistant "\''
+ limits -C daemon su -m homeassistant -c 'sh -c "/usr/sbin/daemon -f -o /var/log/homeassistant.log -P /var/run/homeassistant/homeassistant_daemon.pid -p /var/run/homeassistant/homeassistant.pid -R 1 /usr/local/share/homeassistant/bin/hass --ignore-os-check --config /home/homeassistant/.homeassistant "'
+ _return=0
+ umask 0022
+ [ 0 -ne 0 ]
+ return 0
+ _run_rc_postcmd
+ [ -n homeassistant_poststart ]
+ debug 'run_rc_command: start_postcmd: homeassistant_poststart '
+ eval 'homeassistant_poststart '
+ homeassistant_poststart
+ sleep 1
+ run_rc_command status
+ _return=0
+ rc_arg=status
+ shift 1
+ rc_extra_args=''
+ _rc_prefix=''
+ rc_pid=''
+ _pidcmd=''
+ [ -z status ]
+ [ status '=' enabled ]
+ [ -n '' ]
+ rc_flags=''
+ [ -n '' ]
+ /usr/bin/id -un
+ [ -z '' ]
+ _interpreter=''
+ read _pid _junk
+ [ -z 76372 ]
+ _find_processes /usr/sbin/daemon . '-p 76372'
+ [ 3 -ne 3 ]
+ _interpreter=.
+ _psargs='-p 76372'
+ _pref=''
+ _proccheck=$'\t\t/bin/ps -ww 2>/dev/null -o pid= -o jid= -o command= -p 76372 |
\t\t\t\t_pref=" ";
\t\t\t\tfi
\t\t\t\t;;
\t\t\tesac
\t\tdone'
+ eval /bin/ps -ww '2>/dev/null' -o 'pid=' -o 'jid=' -o 'command=' -p 76372 '|' while read _npid _jid _arg0 '_argv;' do case '"$_arg0"' in '$_procname|$_procnamebn|${_procnamebn}:|"(${_procnamebn})"|"[${_procnamebn}]")' if [ '"$JID"' -eq '"$_jid"' '];' then echo -n '"$_pref$_npid";' '_pref="' '";' fi ';;' esac done
+ /bin/ps -ww -o 'pid=' -o 'jid=' -o 'command=' -p 76372
+ rc_pid=''
+ [ start '!=' status ]
+ continue
+ [ stop '!=' status ]
+ continue
+ [ restart '!=' status ]
+ continue
+ [ rcvar '!=' status ]
+ continue
+ [ enable '!=' status ]
+ continue
+ [ disable '!=' status ]
+ continue
+ [ delete '!=' status ]
+ continue
+ [ enabled '!=' status ]
+ continue
+ [ describe '!=' status ]
+ continue
+ [ extracommands '!=' status ]
+ continue
+ [ status '!=' status ]
+ [ -n homeassistant_enable -a status '!=' rcvar -a status '!=' stop -a status '!=' delete -a status '!=' enable -a status '!=' describe -a status '!=' status ]
+ [ -n homeassistant_enable -a status '=' stop -a -z '' ]
+ [ status '=' start -a -z '' -a -n '' ]
+ eval '_cmd=$status_cmd' '_precmd=$status_precmd' '_postcmd=$status_postcmd'
+ _cmd=homeassistant_status _precmd='' _postcmd=''
+ [ -n homeassistant_status ]
+ [ -n '' ]
+ _run_rc_precmd
+ check_required_before status
+ local _f
+ return 0
+ [ -n '' ]
+ check_required_after status
+ local _f _args
+ return 0
+ return 0
+ _run_rc_doit 'homeassistant_status '
+ local _m
+ debug 'run_rc_command: doit: homeassistant_status '
+ umask
+ _m=0022
+ eval 'homeassistant_status '
+ homeassistant_status
+ [ -n '' ]
+ echo 'homeassistant is not running.'
+ return 1
+ _return=1
+ umask 0022
+ [ 1 -ne 0 ]
+ [ -z '' ]
+ return 1
+ return 1
+ _return=1
+ return 0
+ return 1
The most logical thing I can take out of this is:
su -m homeassistant -c 'sh -c "/usr/sbin/daemon -f -o /var/log/homeassistant.log -P /var/run/homeassistant/homeassistant_daemon.pid -p /var/run/homeassistant/homeassistant.pid -R 1 /usr/local/share/homeassistant/bin/hass --ignore-os-check --config /home/homeassistant/.homeassistant"'
And if I run that directly in the shell it returns immediately with no output and a return code of zero. I can only make it work by removing the `-o`, `-p` and `-P` flags (and their arguments). I can change the values to any other path, e.g. one in the `homeassistant` user's home directory, and it fails silently.
If I set `-P` (aka `--supervisor-daemon`) it
will write a PID but it's a very short-lived process.
Looking at the `daemon` manpage, it does look to me like maybe specifying these options change the way `daemon` works:
-P, --supervisor-pidfile supervisor_pidfile
Write the ID of the daemon process into the supervisor_pidfile
using the pidfile(3) functionality. The program is executed in a
spawned child process while the daemon waits until it terminates
to keep the supervisor_pidfile locked and removes it after the
process exits. The supervisor_pidfile owner is the user who runs
the daemon regardless of whether the --user option is used or
not.
-p, --child-pidfile child_pidfile
Write the ID of the created process into the child_pidfile using
to keep the child_pidfile locked and removes it after the process
exits. The child_pidfile owner is the user who runs the daemon
regardless of whether the --user option is used or not.
If any of the options --child-pidfile, --output-mask, --restart,
--restart-delay, --supervisor-pidfile, --syslog, --syslog-facility
--syslog-priority, --syslog-tag, or --output, are specified, the program
is executed in a spawned child process. The daemon waits until it
terminates to keep the pid file(s) locked and removes them after the
process exits or restarts the program. In this case if the monitoring
daemon receives software termination signal (SIGTERM) it forwards it to
the spawned process. Normally it will cause the child to exit, remove
the pidfile(s) and then terminate.
So I am wondering now if the root cause here is the "spawned child process" somehow not working on my system?
