Thank you for this.
I admit I had some trouble getting it done but now, a couple of hours later, it´s up and running, with my previos config restored and all is well.
I had Radarr running under Mono 5.2, and it was the latest release available (don´t recall the exact version).
Here´s what I did:
Stopped radarr.
copied the config in /usr/local/radarr to a temporary folder locally.
deleted /usr/local/radarr
removed radarr and mono with pkg
Using pkg, I installed Radarrv3-3.1.0.4625_updateable.txz that I had stored in /tmp.
Stopped the jail, and checked allow_mlock under jail properties.
Started jail and confirmed radarr was running under .NET.
tried to upgrade radarr to the current version, which was the same I had before under Mono.
That didn´t work, because of privileges on /tmp/radarr_backup/config.xml. Fixed that and the upgrade went through.
Stopped the jail.
Copied my previously saved config into /usr/local/Radarr
Started the jail.
All done. All my config and movies intact, now running under .NET
Here´s what I did:
Stopped radarr.
Stopped the jail.
Started the jail.
