SOLVED Update Error: %Packages/base-os-12.0-U5.1-2c2e088546e3db7e05cbdf3f818fe373.tgz has invalid checksum
encbox
I'm trying to upgrade from TrueNAS 12.0-U4 to 12.0-U5.1. After downloading the above error message is displayed.
What logfiles should I try to retrieve for more information?
Kris Moore
SVP of Engineering
Administrator
Sounds like a bad download or hiccup on the CDN. If you try it again does it pass now? If its still broken please let us know.
encbox
I rebooted the server and tried again. It is still broken. The server is behind a sophos xg firewall, but there is no filtering activated and it worked before for other upgrades. Maybe I should try again in a few days.
encbox
I further investigated this issue.
If I manually download the base-*.tgz on the truenas server to /tmp its length is 803421816 bytes.
root@freenas[/tmp]# wget https://update-master.ixsystems.com...2.0-U5.1-2c2e088546e3db7e05cbdf3f818fe373.tgz
--2021-08-31 08:50:46-- https://update-master.ixsystems.com...2.0-U5.1-2c2e088546e3db7e05cbdf3f818fe373.tgz
Resolving update-master.ixsystems.com (update-master.ixsystems.com)... 38.126.124.199
Connecting to update-master.ixsystems.com (update-master.ixsystems.com)|38.126.124.199|:443... connected.
HTTP request sent, awaiting response... 302 Moved Temporarily
Location: https://update.freenas.org/TrueNAS/Packages/base-os-12.0-U5.1-2c2e088546e3db7e05cbdf3f818fe373.tgz [following]
--2021-08-31 08:50:46-- https://update.freenas.org/TrueNAS/Packages/base-os-12.0-U5.1-2c2e088546e3db7e05cbdf3f818fe373.tgz
Resolving update.freenas.org (update.freenas.org)... 185.172.148.128, 2a0b:4d07:102::1
Connecting to update.freenas.org (update.freenas.org)|185.172.148.128|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 803421816 (766M) [application/octet-stream]
Saving to: ‘base-os-12.0-U5.1-2c2e088546e3db7e05cbdf3f818fe373.tgz’
base-os-12.0-U5.1-2c2e088546e3db7e05cbdf3f818fe3 100%[==========================================================================================================>] 766.20M 4.20MB/s in 2m 49s
2021-08-31 08:53:36 (4.52 MB/s) - ‘base-os-12.0-U5.1-2c2e088546e3db7e05cbdf3f818fe373.tgz’ saved [803421816/803421816]
shasum -256 is d06870da3c4279af4136433aa48065e79aee152b0c1da0551345dc931c48a3e7 which seems to be correct
root@freenas[/tmp]# shasum -a 256 base-os-12.0-U5.1-2c2e088546e3db7e05cbdf3f818fe373.tgz
d06870da3c4279af4136433aa48065e79aee152b0c1da0551345dc931c48a3e7 base-os-12.0-U5.1-2c2e088546e3db7e05cbdf3f818fe373.tgz
According to /var/log/middlewared.log the truenas gui updater only downloads 639172093 bytes for base-os-12.0-U5.1-2c2e088546e3db7e05cbdf3f818fe373.tgz
I am going to keep you updated.
  • middlewared-log.txt
encbox
I copied the manually download base*.tgz to /var/db/system/update/ and started the update in webgui. That solved the problem...don't know why it didn't work with the download over webgui.
