Harrisonm65
- Apr 29, 2020
Hi all, hope everyone is well.
So, Im not very far into my TrueNAS journey, but recently reprovisioned some old kit to run a small TrueNAS server at home. Nothing fancy at all, just all home grade kit as it is only really going to run a Plex server for now. I built everything up and bar a TRIM issue with the SSD boot pool, all has been fine. Id set this all up in my dining room while I tested it and got things set up and has no issues. However, 2 days ago, I moved the server to the upstairs room that Id like it to live in. Since then though, Ive noticed 2 unscheduled reboots.
First thing this morning when I went in the room the server was moved to and I saw that it was powered off. Did the usual like checking power cables, switches etc and all looked tight. Powered it back on again and saw the alert on my TrueNAS dashboard. Ive just noticed again though that its powered off. Fired it up again and same thing, so now 2 alerts about unscheduled reboots.
Im going to move the server to another location to see if the same problems occur to help rule out the power socket itself. I'll also try new power lead too if needs be. However, my question is, is there anyway to interrogate the logs to look for any signs as to why this might be happening? Maybe too high temps and power surges etc? Not too sure what gets recorded, but if anyone could point me in the right direction to check I would really appreciate it.
Regards
Regards
