Unrecoverable Disk Error question.
mjk79
Hey Guys,
I just ran into a critical disk error that I haven't seen before. I've replaced disks in the past but this one is weird.
Please take a look at the highlighted section of this screen shot and let me know what this could mean.
Thanks for the help!
And while we're at it, smartctl -a /dev/da12 - with [CODE] [/CODE] tags please.
mjk79
The pool just went into Degraded state about an hour ago. Now showing 3.86k under checksum column.
[root@freenas] ~# zpool status
  pool: Vol1
 state: DEGRADED
status: One or more devices has experienced an unrecoverable error.  An
		attempt was made to correct the error.  Applications are unaffected.
   see: http://illumos.org/msg/ZFS-8000-9P
  scan: scrub repaired 0 in 5h24m with 0 errors on Thu Oct  6 14:43:35 2016
		NAME											STATE	 READ WRITE CKSUM
		Vol1											DEGRADED	 0	 0	 0
		  raidz2-0									  DEGRADED	 0	 0	 0
			gptid/87c2bb16-8e12-11e5-8e3d-d05099374ad7  ONLINE	   0	 0	 0
			gptid/8901ec6d-8e12-11e5-8e3d-d05099374ad7  ONLINE	   0	 0	 0
			gptid/89b837ab-8e12-11e5-8e3d-d05099374ad7  ONLINE	   0	 0	 0
			gptid/bd1d6f1c-cc5c-11e5-87c3-d05099374ad7  ONLINE	   0	 0	 0
			gptid/8b4e0206-8e12-11e5-8e3d-d05099374ad7  DEGRADED	 0	 0 3.86K  too many errors
			gptid/8c20f16a-8e12-11e5-8e3d-d05099374ad7  ONLINE	   0	 0	 0
			gptid/8d5cc671-8e12-11e5-8e3d-d05099374ad7  ONLINE	   0	 0	 0
			gptid/8e8cc415-8e12-11e5-8e3d-d05099374ad7  ONLINE	   0	 0	 0
			gptid/8fc6ac11-8e12-11e5-8e3d-d05099374ad7  ONLINE	   0	 0	 0
			gptid/9a7ae7c5-3e7d-11e6-94bb-d05099374ad6  ONLINE	   0	 0	 0
		cache
		  gptid/91428c9e-8e12-11e5-8e3d-d05099374ad7	ONLINE	   0	 0	 0
errors: No known data errors
  pool: Vol_Backup
 state: ONLINE
  scan: scrub repaired 0 in 3h30m with 0 errors on Sat Oct  1 08:40:19 2016
		Vol_Backup									  ONLINE	   0	 0	 0
		  raidz2-0									  ONLINE	   0	 0	 0
			gptid/792fcdbf-dc1f-11e5-9238-d05099374ad7  ONLINE	   0	 0	 0
			gptid/7c6665ad-dc1f-11e5-9238-d05099374ad7  ONLINE	   0	 0	 0
			gptid/7f52c80a-dc1f-11e5-9238-d05099374ad7  ONLINE	   0	 0	 0
			gptid/824f3ed1-dc1f-11e5-9238-d05099374ad7  ONLINE	   0	 0	 0
			gptid/8526311f-dc1f-11e5-9238-d05099374ad7  ONLINE	   0	 0	 0
			gptid/87ef2ba2-dc1f-11e5-9238-d05099374ad7  ONLINE	   0	 0	 0
			gptid/8ad79228-dc1f-11e5-9238-d05099374ad7  ONLINE	   0	 0	 0
			gptid/8e00ce90-dc1f-11e5-9238-d05099374ad7  ONLINE	   0	 0	 0
			gptid/8f6ab128-dc1f-11e5-9238-d05099374ad7  ONLINE	   0	 0	 0
			gptid/8ffe5dee-dc1f-11e5-9238-d05099374ad7  ONLINE	   0	 0	 0
			gptid/9091917e-dc1f-11e5-9238-d05099374ad7  ONLINE	   0	 0	 0
			gptid/91271704-dc1f-11e5-9238-d05099374ad7  ONLINE	   0	 0	 0
  pool: freenas-boot
 state: ONLINE
  scan: scrub repaired 0 in 0h9m with 0 errors on Fri Sep 30 03:54:09 2016
		freenas-boot								  ONLINE	   0	 0	 0
		  gptid/b01c2858-a80a-11e4-a607-d05099374ad6  ONLINE	   0	 0	 0
[root@freenas] ~# smartctl -a /dev/da12
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:	 Western Digital Red
Device Model:	 WDC WD60EFRX-68MYMN1
Serial Number:	WD-WX11D35C8ZEV
LU WWN Device Id: 5 0014ee 2b6cc911d
Firmware Version: 82.00A82
User Capacity:	6,001,175,126,016 bytes [6.00 TB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Rotation Rate:	5700 rpm
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:	Fri Oct  7 12:55:42 2016 MDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
										was never started.
Self-test execution status:	  (   0) The previous self-test routine completed
										been run.
data collection:				( 4244) seconds.
capabilities:					(0x7b) SMART execute Offline immediate.
										command.
										Self-test supported.
SMART capabilities:			(0x0003) Saves SMART data before entering
										power-saving mode.
Error logging capability:		(0x01) Error logging supported.
Short self-test routine
recommended polling time:		(   2) minutes.
Extended self-test routine
recommended polling time:		( 696) minutes.
Conveyance self-test routine
recommended polling time:		(   5) minutes.
SCT capabilities:			  (0x303d) SCT Status supported.
										SCT Data Table supported.
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x002f   200   200   051	Pre-fail  Always	   -	   0
  3 Spin_Up_Time			0x0027   222   195   021	Pre-fail  Always	   -	   7883
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   53
  5 Reallocated_Sector_Ct   0x0033   200   200   140	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x002e   200   200   000	Old_age   Always	   -	   0
  9 Power_On_Hours		  0x0032   086   086   000	Old_age   Always	   -	   10356
 10 Spin_Retry_Count		0x0032   100   253   000	Old_age   Always	   -	   0
 11 Calibration_Retry_Count 0x0032   100   253   000	Old_age   Always	   -	   0
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   53
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   50
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   152
194 Temperature_Celsius	 0x0022   116   101   000	Old_age   Always	   -	   36
196 Reallocated_Event_Count 0x0032   200   200   000	Old_age   Always	   -	   0
197 Current_Pending_Sector  0x0032   200   200   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0030   100   253   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x0032   200   200   000	Old_age   Always	   -	   0
200 Multi_Zone_Error_Rate   0x0008   200   200   000	Old_age   Offline	  -	   0
SMART Error Log Version: 1
No Errors Logged
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline	   Completed without error	   00%	 10300		 -
# 2  Short offline	   Completed without error	   00%	 10086		 -
# 3  Extended offline	Completed without error	   00%	 10002		 -
# 4  Short offline	   Completed without error	   00%	  9918		 -
# 5  Short offline	   Completed without error	   00%	  9750		 -
# 6  Extended offline	Completed without error	   00%	  9666		 -
# 7  Short offline	   Completed without error	   00%	  9582		 -
# 8  Short offline	   Completed without error	   00%	  9343		 -
# 9  Extended offline	Completed without error	   00%	  9259		 -
#10  Short offline	   Completed without error	   00%	  9175		 -
#11  Short offline	   Completed without error	   00%	  9007		 -
#12  Extended offline	Completed without error	   00%	  8923		 -
#13  Short offline	   Completed without error	   00%	  8839		 -
#14  Short offline	   Completed without error	   00%	  8599		 -
#15  Extended offline	Completed without error	   00%	  8515		 -
#16  Short offline	   Completed without error	   00%	  8431		 -
#17  Short offline	   Completed without error	   00%	  8263		 -
#18  Extended offline	Completed without error	   00%	  8179		 -
#19  Short offline	   Completed without error	   00%	  8096		 -
#20  Short offline	   Completed without error	   00%	  7881		 -
#21  Extended offline	Completed without error	   00%	  7797		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
m0nkey_
The disk looks fine. You can try clearing the error and run another scrub, see if the disk degrades again. If it does, it's time to replace it.
zpool clear <pool>
zpool scrub <pool>
Robert Trevellyan
Pony Wrangler
Are you absolutely certain that gptid/8b4e0206-8e12-11e5-8e3d-d05099374ad7 == /dev/da12?
If so, given how healthy the disk looks, you might have some other kind of hardware issue, perhaps as simple as a bad cable.
