undeletable file in ZFS volume
parpar
I have a problem deleting/opening a file in Freenas 8.3.0 on a raidz-1 volume with lzjb compression:
This is what ls says:
ls
ls: 02 Walking By Myself.m4a: No such file or directory
and find lists it normally:
find .
./02 Walking By Myself.m4a
I cannot get rid of the "02 Walking By Myself.m4a" file, nor its enclosing directory. Touch, rm -rf, chmod, getfacl all claim the file does not exist and do nothing. The file system is nowhere full (nor has it ever been).
I did a scrub on the volume, didn't find nor repaired any errors.
zdb on its inode gives:
zdb -dddddd zdata/SharedData 42456
<snip>
   Object  lvl   iblk   dblk  dsize  lsize   %full  type
zdb: dmu_bonus_hold(42456) failed, errno 2
Any suggestions how I can rid of that darned file?
HolyK
Ninja Turtle
I guess the whitespace could be the "problem". Use single quote arround the filename or escape the space, so..
rm '02 Walking By Myself.m4a'
or
rm 02\ Walking\ By\ Myself.m4a
BTW: Get rid of the spaces in filenames on unix ;)
parpar
That is exactly what I did HolyKiller. I also checked the name for any other UTF8 hidden characters and performed a
find . -exec rm -rf {} \;
to no avail.
It is also not a permission problem: I am root and working from an ssh session
I believe this is a bug in ZFS or undetected corruption by scrub (which is why Im posting it here)
Any other suggestions?
HolyK
Ninja Turtle
Do you have any quota set for that dataset?
Or you can try this:
or maybe a bit better is this:
cp -f /dev/null '02 Walking By Myself.m4a'
and then try to remove it again.
parpar
There is no quota set (0) on that dataset, which has 2.7 TB free. The results of your other two suggestions are:
cp -f /dev/null 02\ Walking\ By\ Myself.m4a
cp: 02 Walking By Myself.m4a: No such file or directory
and
Invalid null command.
but also
echo > 02\ Walking\ By\ Myself.m4a
02 Walking By Myself.m4a: No such file or directory.
No luck..
William Grzybowski
Well, I don't see any other way around other than create a new dataset, move everything and then destroy the old dataset.
What FreeNAS version are you running?
parpar
Thanks William,
I'm on FreeNAS 8.3.0 (FreeBSD 8.3-RELEASE-p5 64bit on an AMD64). Any idea how this mishap can occur? Although it is not a problem to recreate the dataset (I have a backup + numerous snapshots), I'd like to know what could cause it and/or prevent it from happening again. Any suggestions on how to best move everything (clone a snapshot and promote it? rsync the dataset, zfs send | receive?)
Thanks for the support,
Paul
parpar
Just discovered that the error replicated to my backup server as well (synced with autorepl.py), so
zfs send | zfs receive
may not be a good idea to get rid of the file..
William Grzybowski
No idea how that happened, some kind of obscure bug I'd think.
I would use rsync to another dataset, as you figured b yourself send + recv might replicate the bug as well.
joeschmuck
Old Man
Could you just share that directory as an FTP share and then use something like Filezilla, then delete the file that way?
parpar
@joeschmuck: I doubt whether ftpd has a different method to unlink a file than rm/unlink. Just to make sure I tried your suggestion on the dataset that contained the error and tried to remove the containing directory and the following error was reported:
550 /mnt/zdata/oldShared/..../oo: Directory not empty.
the oo directory contained only the undeletable file, which is not shown in the FTP list (just as 'ls' doesn't do it but reports an error).
I meanwhile followed William Grzybowski's advice and rsynced the dataset over to a fresh one. As expected rsync didn't copy over the hidden and undeletable file, so I expect the new dataset is error free. Fingers corssed it won't happen again to more important files..
Thanks all for the support!
Paul
