Here are the smartctl results. I didn't post it at first since it's a bit lengthy. The drive that had the checksum error was /dev/da2.
Hardware setup is pretty straightforward.
Motherboard: ASRock C2750D4i Avoton server and using LSI 9240-8i SATA controllers.
Memory: Crucial 16GB (8GBx2) DDR3 PC3-12800 ECC UDIMM
smartctl -a /dev/da0
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p10 amd64] (local build)
Model Family: Western Digital Red
Device Model: WDC WD30EFRX-68EUZN0
Serial Number: <snip>
LU WWN Device Id: 5 0014ee 209505929
Firmware Version: 80.00A80
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon May 18 10:53:09 2015 PDT
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: (40500) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 406) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 176 175 021 Pre-fail Always - 6200
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 17
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 098 098 000 Old_age Always - 2016
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 17
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 16
193 Load_Cycle_Count 0x0032 192 192 000 Old_age Always - 26971
194 Temperature_Celsius 0x0022 121 114 000 Old_age Always - 29
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
smartctl -a /dev/da1
LU WWN Device Id: 5 0014ee 25f3d6e3a
Local Time is: Mon May 18 10:55:04 2015 PDT
was never started.
been run.
data collection: (39900) seconds.
command.
power-saving mode.
recommended polling time: ( 400) minutes.
3 Spin_Up_Time 0x0027 180 180 021 Pre-fail Always - 5983
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 16
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 16
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 15
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 6
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
smartctl -a /dev/da2
LU WWN Device Id: 5 0014ee 209e76210
Local Time is: Mon May 18 10:55:47 2015 PDT
was never started.
been run.
data collection: (38760) seconds.
command.
power-saving mode.
recommended polling time: ( 389) minutes.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 1
3 Spin_Up_Time 0x0027 176 176 021 Pre-fail Always - 6166
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 5
194 Temperature_Celsius 0x0022 120 114 000 Old_age Always - 30
No Errors Logged
# 1 Short offline Completed without error 00% 2014 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
smartctl -a /dev/da3
LU WWN Device Id: 5 0014ee 2b3fbedec
Local Time is: Mon May 18 10:56:23 2015 PDT
was never started.
been run.
data collection: (39240) seconds.
command.
power-saving mode.
recommended polling time: ( 394) minutes.
3 Spin_Up_Time 0x0027 178 178 021 Pre-fail Always - 6083
9 Power_On_Hours 0x0032 098 098 000 Old_age Always - 2015
193 Load_Cycle_Count 0x0032 192 192 000 Old_age Always - 26954
194 Temperature_Celsius 0x0022 119 113 000 Old_age Always - 31
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
smartctl -a /dev/da4
LU WWN Device Id: 5 0014ee 2b3fbe695
Local Time is: Mon May 18 10:57:46 2015 PDT
was never started.
been run.
data collection: (38580) seconds.
command.
power-saving mode.
recommended polling time: ( 387) minutes.
3 Spin_Up_Time 0x0027 175 174 021 Pre-fail Always - 6250
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 23
9 Power_On_Hours 0x0032 095 095 000 Old_age Always - 3693
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 23
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 17
193 Load_Cycle_Count 0x0032 199 199 000 Old_age Always - 5826
194 Temperature_Celsius 0x0022 123 111 000 Old_age Always - 27
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
