milesnorth
- Dec 9, 2017
I'm running FreeNAS-11.1-U1 and am unable to update using the GUI. I built the system last fall and have done very little modifications since then. The only LAN change that affected FreeNAS during this time was changing the Smoothwall Express green interface from 10.0.0.1 to a new IP address.
Clicking the <Check Now> button in the Update section of the FreeNAS GUI eventually yields the following message:
Other messages when I logged into the GUI today include:
Help would be greatly appreciated.
Thanks,
Kurt
Update server could not be reached <urlopen error timed out> Traceback Traceback (most recent call last): File "/usr/local/lib/python3.6/urllib/request.py", line 1318, in do_open encode_chunked=req.has_header('Transfer-encoding')) File "/usr/local/lib/python3.6/http/client.py", line 1239, in request self._send_request(method, url, body, headers, encode_chunked) File "/usr/local/lib/python3.6/http/client.py", line 1285, in _send_request self.endheaders(body, encode_chunked=encode_chunked) File "/usr/local/lib/python3.6/http/client.py", line 1234, in endheaders self._send_output(message_body, encode_chunked=encode_chunked) File "/usr/local/lib/python3.6/http/client.py", line 1026, in _send_output self.send(msg) File "/usr/local/lib/python3.6/http/client.py", line 964, in send self.connect() File "/usr/local/lib/python3.6/http/client.py", line 936, in connect (self.host,self.port), self.timeout, self.source_address) File "/usr/local/lib/python3.6/socket.py", line 724, in create_connection raise err File "/usr/local/lib/python3.6/socket.py", line 713, in create_connection sock.connect(sa) socket.timeout: timed out During handling of the above exception, another exception occurred: Traceback (most recent call last): File "./freenasUI/system/views.py", line 1607, in update_check train=updateobj.get_train(), File "./freenasUI/system/models.py", line 599, in get_train trains = conf.AvailableTrains() or [] File "/usr/local/lib/freenasOS/Configuration.py", line 1064, in AvailableTrains fileref = self.TryGetNetworkFile(file=TRAIN_FILE, reason="FetchTrains") File "/usr/local/lib/freenasOS/Configuration.py", line 787, in TryGetNetworkFile raise url_exc File "/usr/local/lib/freenasOS/Configuration.py", line 761, in TryGetNetworkFile furl = opener.open(req, timeout=30) File "/usr/local/lib/python3.6/urllib/request.py", line 526, in open response = self._open(req, data) File "/usr/local/lib/python3.6/urllib/request.py", line 544, in _open '_open', req) File "/usr/local/lib/python3.6/urllib/request.py", line 504, in _call_chain result = func(*args) File "/usr/local/lib/python3.6/urllib/request.py", line 1346, in http_open return self.do_open(http.client.HTTPConnection, req) File "/usr/local/lib/python3.6/urllib/request.py", line 1320, in do_open raise URLError(err) urllib.error.URLError: <urlopen error timed out>
Sep 3 00:00:00 freenas syslog-ng[4533]: Configuration reload request received, reloading configuration; Sep 3 00:06:09 freenas /alert.py: [freenasOS.Configuration:772] Unable to load http://update-master.ixsystems.com/updates/ix_crl.pem: <urlopen error timed out> Sep 3 00:06:09 freenas /alert.py: [freenasOS.Configuration:786] Unable to load ['http://update-master.ixsystems.com/updates/ix_crl.pem']: <urlopen error timed out> Sep 3 00:06:09 freenas /alert.py: [freenasOS.Manifest:452] Could not get CRL file http://update-master.ixsystems.com/updates/ix_crl.pem Sep 3 00:06:41 freenas /alert.py: [freenasOS.Configuration:772] Unable to load http://update-master.ixsystems.com/updates/ix_crl.pem: <urlopen error timed out> Sep 3 00:06:41 freenas /alert.py: [freenasOS.Configuration:786] Unable to load ['http://update-master.ixsystems.com/updates/ix_crl.pem']: <urlopen error timed out> Sep 3 00:06:41 freenas /alert.py: [freenasOS.Manifest:452] Could not get CRL file http://update-master.ixsystems.com/updates/ix_crl.pem
Thanks,
Kurt
