dftwd-admin
- Feb 9, 2020
To all that may advise,
I have had this issue for a bit now. I have essentially just ignored until today. Its finally bugged me enough to deal with it. I cannot seam to get FreeNAS to update on the CLI or the WebGUI. I get these errors. From the WebGUI I get
From the CLI using "freenas-update -v check" I get
I can ping dns.google.com which resolvs to 8.8.8.8 of course and I can ping update-master.ixsystems.com.
I'm chasing my tail here. Any ideas on what I should do short of reinstalling FreeNAS and restoring a config. That's such a short way out that doesn't hardly result in learning ways around FreeBSD or FreeNAS for that matter. Please advise.
Thanks in Advance,
DFTWD-ADMIN
Update server could not be reached b'' Traceback Traceback (most recent call last): File "/usr/local/lib/freenasOS/Manifest.py", line 682, in RunValidationProgram subprocess.check_output(valid_script, preexec_fn=PreExecHook, stderr=subprocess.STDOUT) File "/usr/local/lib/python3.6/subprocess.py", line 356, in check_output **kwargs).stdout File "/usr/local/lib/python3.6/subprocess.py", line 438, in run output=stdout, stderr=stderr) subprocess.CalledProcessError: Command './tmp2bbz755h' died with <Signals.SIGABRT: 6>. During handling of the above exception, another exception occurred: Traceback (most recent call last): File "./freenasUI/system/views.py", line 1686, in update_check train=updateobj.get_train(), File "/usr/local/lib/freenasOS/Update.py", line 863, in CheckForUpdates new_manifest.RunValidationProgram(cache_dir) File "/usr/local/lib/freenasOS/Manifest.py", line 684, in RunValidationProgram raise Exceptions.UpdateInvalidUpdateException(err.output.rstrip())
% freenas-update -v check [freenasOS.Configuration:601] TryGetNetworkFile(['https://update-master.ixsystem s.com/FreeNAS/FreeNAS-11.2-STABLE/LATEST']) [freenas-update:195] [Errno 13] Permission denied: '/var/db/system/tmpql4i1u77' Traceback (most recent call last): File "/usr/local/bin/freenas-update", line 169, in DoDownload rv = Update.DownloadUpdate(train, cache_dir, pkg_type=pkg_type, ignore_space =ignore_space) File "/usr/local/lib/freenasOS/Update.py", line 898, in DownloadUpdate latest_mani = conf.FindLatestManifest(train, require_signature=True) File "/usr/local/lib/freenasOS/Configuration.py", line 1090, in FindLatestMani fest reason="GetLatestManifest", File "/usr/local/lib/freenasOS/Configuration.py", line 639, in TryGetNetworkFi le retval = tempfile.TemporaryFile(dir=self._temp) File "/usr/local/lib/python3.6/tempfile.py", line 622, in TemporaryFile (fd, name) = _mkstemp_inner(dir, prefix, suffix, flags, output_type) File "/usr/local/lib/python3.6/tempfile.py", line 262, in _mkstemp_inner fd = _os.open(file, flags, 0o600) PermissionError: [Errno 13] Permission denied: '/var/db/system/tmpql4i1u77' Received exception during download phase, cannot update
Thanks in Advance,
DFTWD-ADMIN
