pclausen
- Apr 19, 2015
I have a drive where the SMART error counts started to increase, so as a preventive measure, I added a replacement disk in a spare bay and resilvered to it.  I then OFFLINED it, pulled out the old drive and inserted the new one.  But then I then attempted to ONLINE the new drive, I got the following error:
Any ideas?
Here's the action I'm trying to perform that throws the above error:
This is the third drive I have replaced, following the exact same procedure. The only difference I can think off is that I'm on a newer stable release now (FreeNAS-9.3-STABLE-201506232120) than I was when replacing the previous 2 disks.
Should I reboot the server and then attempt another ONLINE action?
Resilver itself completed with no errors. In fact, it was flying this time:
Jun 26 12:10:01 freenas notifier: swapoff: /dev/da28p1.eli: No such file or directory Jun 26 12:10:01 freenas notifier: geli: No such device: /dev/da28p1. Jun 26 12:10:01 freenas notifier: 1+0 records in Jun 26 12:10:01 freenas notifier: 1+0 records out Jun 26 12:10:01 freenas notifier: 1048576 bytes transferred in 0.471564 secs (2223613 bytes/sec) Jun 26 12:10:01 freenas notifier: dd: /dev/da28: short write on character device Jun 26 12:10:01 freenas notifier: dd: /dev/da28: end of device Jun 26 12:10:01 freenas notifier: 5+0 records in Jun 26 12:10:01 freenas notifier: 4+1 records out Jun 26 12:10:01 freenas notifier: 4284416 bytes transferred in 0.012649 secs (338714200 bytes/sec) Jun 26 12:10:06 freenas notifier: swapoff: /dev/da28p1.eli: No such file or directory Jun 26 12:10:06 freenas notifier: geli: No such device: /dev/da28p1. Jun 26 12:10:06 freenas manage.py: [middleware.exceptions:38] [MiddlewareError: Disk replacement failed: "invalid vdev specification, use '-f' to override the following errors:, /dev/gptid/cdba2e5c-1c1d-11e5-8714-0cc47a3311b4 is part of active pool 'v1', "]
Any ideas?
pool: v1 state: ONLINE status: One or more devices is currently being resilvered. The pool will continue to function, possibly in a degraded state. action: Wait for the resilver to complete. scan: resilver in progress since Fri Jun 26 06:22:25 2015 17.0T scanned out of 58.4T at 3.82G/s, 3h5m to go 208G resilvered, 29.10% done
