SOLVED unable to load /api/v1.0/storage/volume status :500
Fei
Hi All
Today I upgrade my system from 9.3-Nightlies-20160219 to 9.3-stable-20160203
I check WebUI -> Storage it show unable to load /api/v1.0/ status 500
How to fix it?
< statble-20160203>
<nightlies-20160219>
  • debug-20160309194757..tgz
D
dlavigne
Guest
Yeah, the system doesn't like it when you upgrade from a nightly to a stable. Have you run a stable release before? If so, you should boot into that boot environment and do the upgrade from there.
Fei
If my dataset is create on nightly,it can import on stable version?
D
dlavigne
Guest
The storage is separate from the OS drive, so any pools, datasets, etc. aren't affected by the OS changing.
Well, that sucks. It's a very convenient way to get 9.3.1 installed on Skylake systems.
D
dlavigne
Guest
Yup, though in that case, one should stay on the nightly train...
noobnas
Hi
Thanks your response , it is resolve.
What exactly resolved it. I'm upgrading from freenas 11.0 RC to the 11.0 release, and my pool keep disappearing until I downgrade.
