So awhile back I changed to the nightlies train as I'd read it fixed an issue I was having. Now I want to get back to the Stable train and I'm having a few issues.
After I rollback to stable it will not import my pool (volume?). It doesn't even show the storage tab in the left column of the GUI. If I click on the storage icon on the top row of the GUI it just says:
"unable to load /api/v1.0/storage/volume status :500" in the storage/volumes tab where it would normally show my volume. The "import pool" button just gives me an Operational Error exception after I start the import.
I thought I saved the txt of the following but I only had a screenshot. I did find some commands on the forum that sounded like they might be able to fix this based on the search of: "unable to load /api/v1.0/storage/volume status :500"
One more, screenshot so you can see the missing storage tab on the left.
Right now I'm running 11-Master-201708290409, trying to move to the latest 11 release. The results are the same on 11.0-RELEASE, 11.0-U2, & 11.0-U4.
Please point me in the proper direction if it's possible to do this. I'd really like to get back on the stable train so I don't have to cross my fingers every time I hit update.
