Unable to install plugins or jails on either FreeNAS system
MikeyG
I have two machines running FreeNAS. One of them is only a few weeks old, and I've never done anything with jails or plugins on it. Both are running 11.1-U2.
When I try to install any of the plugins, I get the error:
ERROR: missing files
cannot open 'MirrorPool/jails/.warden-template-pluginjail': dataset does not exist
find: /mnt/MirrorPool/jails/.warden-template-pluginjail: No such file or directory
ERROR: Failed to create ZFS base dataset
When I try to create a new jail, it just sits there for a long time and nothing happens.
On one of the installs, I tried reverting back to 11.1-U1 but nothing changed.
On the new install, I don't have the dataset it's referring to:
NAME														  USED  AVAIL  REFER  MOUNTPOINT
MirrorPool												   8.01T  4.28T	88K  /mnt/MirrorPool
MirrorPool/.system											704M  4.28T	96K  legacy
MirrorPool/.system/configs-d6d294a404024d4b9f621e6bf1afa53c  2.02M  4.28T  2.02M  legacy
MirrorPool/.system/cores									  702M  4.28T   702M  legacy
MirrorPool/.system/rrd-d6d294a404024d4b9f621e6bf1afa53c		88K  4.28T	88K  legacy
MirrorPool/.system/samba4									 328K  4.28T   328K  legacy
MirrorPool/.system/syslog-d6d294a404024d4b9f621e6bf1afa53c	 88K  4.28T	88K  legacy
MirrorPool/Files											 8.01T  4.28T  7.82T  /mnt/MirrorPool/Files
MirrorPool/jails											 31.1M  4.28T  31.1M  /mnt/MirrorPool/jails
SSDPool													  86.1G   833G   149K  /mnt/SSDPool
SSDPool/Scratchdisk										  86.1G   833G  86.1G  /mnt/SSDPool/Scratchdisk
freenas-boot												 2.06G   229G   176K  none
freenas-boot/ROOT											2.05G   229G   136K  none
freenas-boot/ROOT/11.1-U2									2.05G   229G  1.10G  /
freenas-boot/ROOT/Initial-Install							   8K   229G   971M  legacy
freenas-boot/ROOT/default									 276K   229G   971M  legacy
freenas-boot/grub											7.82M   229G  7.82M  legacy
So I tried running warden template create -nick pluginjail -tar http://download.freenas.org/jails/11/x64/freenas-pluginjail-11.0-RELEASE.tgz but that didn't help.
Network is fine - I'm able to ping google.com from both install.
Any ideas?
Do you have the default gateway and DNS set up in the network configuration.
Also hardware does matter in troubleshooting so it needs to be posted.
MikeyG
Yes, network has default gateway and DNS set up.
Supermicro X11SSH-CTF
i3-7320
2X Crucial CR16G4WFD824 16GB ECC
Seasonic Focus 650W 80 Plus Gold
2X ST8000NM0055
6X ST2000NM0033
MikeyG
Also here is what creating a jail looks like:
Says "Dataset does not exist" in the error.....
Go check your settings for the jail and correct it. Probably should start with /mnt/xxxxxxx
MikeyG
What settings? The only place I see to specify location is under Jails -> Configuration and that information is correct. In the example I posted, I had created a new dataset at /mnt/SSDPool/Jails and pointed the jail configuration to it. .warden-template-standard did not already exist, but I thought it was created automatically. In the past, I have never had to create any templates in order to create jails.
MikeyG
Figured this out. IPv6 stopped working on my ISP side, although it was still handing out IPs which FreeNAS was attempting to use for downloading jail and plugin data.
Pings from within the terminal looked normal as I wasn't specifying ping6.
Disabled ipv6 on FreeNAS and everything started working again.
