Unable to install on HP DL360 G3
US1
I need to install FreeNas 8 on an old HP Proliant DL360 G3 server. I booted the FreeNAS-8.0-RELEASE-i386.iso but after a while the machine hangs completly. So it's impossible to complete the installation. A screenshot is attached.
Can sombody help me? Sorry for my english.
Uwe
US1
Yes, after disabling USB it hangs after:
md0: Preload image...
Uwe
US1
I just tested the FreeNAS-i386-LiveCD-0.7.2.6694.iso, it boots without problems.
But I would prefer to use V 8.
Uwe
US1
Does this mean, it's impossible to install FreeNAS 8 on standard hardware like DL360 G3?
US1
Yes, I already tried this, I also tried with APIC diabled in the BIOS.
mordek
Ive also got same problem. My hardware is HP DL380 G3. The hangs are at the same moments.
ApolloDS
Same problem...
Exactly the same problem here.
Tried many setup options "Other OS", Safe Mode, No ACPI etc.etc. nothing works.
ApolloDS
** SOLVED ** Unable to install HP DL380 G3
Hello again
I just solved the problem with installation.
I used Version 8.0.3 of FreeNAS via iLO Virtual CDROM Remote Installation to do the installation. This was stopping always at the usb devices and the machine hangs.
The trick is to disable in the BIOS the Virtual Media in Advanced Options and to boot FreeNAS Installation without ACPI.
Then the installation starts on the DL380.
After FreeBSD is installed you need to disable the HP PCI USB Controller in the BIOS so that FreeNAS will boot on this Hardware.
