Hi All
I have been running Freenas 9.3 on my HP Microserver with two 2TB HDD's for data storage. I have installed a new operating system drive and have installed a fresh copy of TrueNAS-12.0-U5.1. I have attempted to import the two drives in order to make them active and browsable etc but none of the options in the 'Import Drive' section work.
I can see the two drives:
/dev/ada0p1
/dev/ada0p2
/dev/ada1p1
/dev/ada1p2
I have set the Destination Path to /mnt
I have attempted to import the drives with :
USF
NTFS
MSDOSFS
EXT2FS
All of these options fails with errors.
Can you advise?
Prior to installing TrueNAS-12.0-U5.1 the drives were working Ok. Freenas 9.3 has been fine on this server since it's release.
/dev/ada0p1
/dev/ada0p2
/dev/ada1p1
/dev/ada1p2
USF
NTFS
MSDOSFS
EXT2FS
Can you advise?
