Error: concurrent.futures.process._RemoteTraceback:
File "/usr/lib/python3.11/concurrent/futures/process.py", line 256, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 112, in main_worker
res = MIDDLEWARE._run(*call_args)
File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 46, in _run
return self._call(name, serviceobj, methodobj, args, job=job)
File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 34, in _call
with Client(f'ws+unix://{MIDDLEWARE_RUN_DIR}/middlewared-internal.sock', py_exceptions=True) as c:
File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 40, in _call
return methodobj(*params)
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 50, in nf
res = f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 181, in nf
return func(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs_/dataset.py", line 169, in do_update
with libzfs.ZFS() as zfs:
File "libzfs.pyx", line 529, in libzfs.ZFS.__exit__
File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs_/dataset.py", line 178, in do_update
self.update_zfs_object_props(properties, dataset)
File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs_/dataset.py", line 247, in update_zfs_object_props
verrors.check()
File "/usr/lib/python3/dist-packages/middlewared/service_exception.py", line 70, in check
raise self
middlewared.service_exception.ValidationErrors: [EINVAL] properties.org.freenas:quota_warning: Property does not exist and cannot be inherited
[EINVAL] properties.org.freenas:quota_critical: Property does not exist and cannot be inherited
[EINVAL] properties.org.freenas:refquota_warning: Property does not exist and cannot be inherited
[EINVAL] properties.org.freenas:refquota_critical: Property does not exist and cannot be inherited
The above exception was the direct cause of the following exception:
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 201, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1342, in _call
File "/usr/lib/python3/dist-packages/middlewared/service/crud_service.py", line 180, in update
return await self.middleware._call(
File "/usr/lib/python3/dist-packages/middlewared/service/crud_service.py", line 197, in nf
rv = await func(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 44, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 177, in nf
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/dataset.py", line 894, in do_update
await self.middleware.call('zfs.dataset.update', id, {'properties': props})
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1399, in call
return await self._call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1350, in _call
return await self._call_worker(name, *prepared_call.args)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1356, in _call_worker
return await self.run_in_proc(main_worker, name, args, job)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1267, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1251, in run_in_executor
