Elliott
- Sep 13, 2019
I'm creating several pools with different settings for testing and I noticed some disks won't let me create a zpool. Apparently the OS thinks the drive is busy, but how can I find out what's holding it?
root@freenas ~ # zpool create fred da14
cannot create 'fred': no such pool or dataset
root@freenas ~ # gpart show da14
=> 40 19532873648 da14 GPT (9.1T)
40 88 - free - (44K)
128 4194304 1 freebsd-swap (2.0G)
4194432 19528679256 2 freebsd-zfs (9.1T)
root@freenas ~ # gpart destroy -F da14
gpart: Device busy
root@freenas ~ # dd if=/dev/zero of=/dev/da14
dd: /dev/da14: Operation not permitted
root@freenas ~ # smartctl -a /dev/da14
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Vendor: HGST
Product: HUH721010AL5200
Revision: A384
Compliance: SPC-4
User Capacity: 10,000,831,348,736 bytes [10.0 TB]
Logical block size: 512 bytes
Physical block size: 4096 bytes
LU is fully provisioned
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Logical Unit id: 0x5000cca2674cb104
Serial number: JEHB5HPN
Device type: disk
Transport protocol: SAS (SPL-3)
Local Time is: Tue Oct 1 18:01:25 2019 PDT
SMART support is: Enabled
Temperature Warning: Enabled
SMART Health Status: OK
Current Drive Temperature: 42 C
Drive Trip Temperature: 85 C
Manufactured in week 47 of year 2018
Specified cycle count over device lifetime: 50000
Accumulated start-stop cycles: 52
Specified load-unload count over device lifetime: 600000
Accumulated load-unload cycles: 99
Elements in grown defect list: 0
Vendor (Seagate) cache information
Blocks sent to initiator = 385835031592960
Error counter log:
Errors Corrected by Total Correction Gigabytes Total
ECC rereads/ errors algorithm processed uncorrected
fast | delayed rewrites corrected invocations [10^9 bytes] errors
read: 0 0 0 0 7891 583.598 0
write: 0 0 0 0 2551 4672.373 0
verify: 0 0 0 0 324 0.007 0
Non-medium error count: 0
No self-tests have been logged
root@freenas ~ # zpool status
pool: double
state: ONLINE
scan: none requested
NAME STATE READ WRITE CKSUM
double ONLINE 0 0 0
da2 ONLINE 0 0 0
da3 ONLINE 0 0 0
errors: No known data errors
pool: freenas-boot
state: ONLINE
freenas-boot ONLINE 0 0 0
ada0p2 ONLINE 0 0 0
pool: quad
state: ONLINE
quad ONLINE 0 0 0
da4 ONLINE 0 0 0
da5 ONLINE 0 0 0
da6 ONLINE 0 0 0
da7 ONLINE 0 0 0
pool: single
state: ONLINE
single ONLINE 0 0 0
da1 ONLINE 0 0 0
